20 Most Recent
Cellular Innovations HFBLU-CX1 Wireless Headset Questions & Answers
Syncing the HFBLU-10K with the iphone
for iphone : set your phone to scan for wireless device
1 unlock
2 settings icon
3 general
4 bluetooth ON
the hold the big button on the blue tooth once it flashes blue DO NOT LET GO! keep holding it till it flashs red and blue red and blue then let go and it should find it instantly then press on the BK-600 word and enter the 0000 code and you should be all set.
9/9/2014 12:25:03 PM •
Cellular...
Answered
on Sep 09, 2014
Bluetooth headset will not pair up with my LG DARE
Had the same problem. Paired fine with multiple devices (headset, computer, auto.) Then all of sudden BT will not connect. Cannot re-pair (unable to find device(s)). Had 1st phone replaced. Within about 6 months, the 2nd Dare did the same thing.
3/1/2011 10:56:11 PM •
Cellular...
Answered
on Mar 01, 2011
LOST PASS KEY
Most blue tooth manufactures use a 4 digit pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
2/22/2011 8:01:25 AM •
Cellular...
Answered
on Feb 22, 2011
I just bought the hfblu-10k
I was given this bluetooth after a buddy of mine could'nt figure it out. I figured out how to sync it by following that longer than 5 secs. idea that's posted here. I did'nt have a manual so I just put in "0000" and it worked! So try that...Good Luck. Thanx4Hating
12/24/2010 1:40:58 AM •
Cellular...
Answered
on Dec 24, 2010
I am unable to pair
When you put the device into pair mode and find it on your phone. You select the device and what happens, what do you mean go away? Try doing a hard reset on your phone, to do this remove the battery from your phone while it is powered on. Reboot it, when it comes back again re-attempt to pair the device to your phone (make sure it is still in pair mode).
Rylan
12/16/2010 8:59:38 PM •
Cellular...
Answered
on Dec 16, 2010
What is the pass key
The passkey is just "0000" without the quotes of course.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
10/19/2010 8:38:35 PM •
Cellular...
Answered
on Oct 19, 2010
Can not find Blutooth Headset, Model: HFBLU-LT100
Please make sure the bluetooth is in pairing mode, you know this when the unit is flashing red/blue at the same time. you can achieve this by first turning the unit completely off. once the unit is off then hold down the power button until you see the re/blue flashing light. then have your phone search for a new device again. if this does not work you can always take the battery out of your phone while it is still on (for about 5-10 seconds) so that it can reset. then try the process again.
1/29/2010 7:11:14 PM •
Cellular...
Answered
on Jan 29, 2010
