20 Most Recent Plantronics Explorer 330 Headset Questions & Answers
Make sure its fully charged, turn the headset off, press the call control button for 6 seconds, then try look for the headset on your phone.
Passkey is 0000
Plantronics... | Answered on Oct 20, 2013
After looking through the phones, there many possibilities, wow quite a few. It does not have any recommendations on headsets. The headset is only as good as the the quality you are purchasing. If your phone drops calls it won't be from the bluetooth device. Below is a link to the Explorer Series 300 User's Guide, which may help you.
Plantronics Explorer Series 300 User's Guide
Good luck from Headsets Direct!
Plantronics... | Answered on Dec 14, 2011
The link below is for the user guide that has the instructions on page 4 on pairing the headset to your phone. Please bear in mind that newer phones are like small computers, so they may become corrupt over time and you may need to reset them every so often. Simply turn your phone off and remove again the battery for a few seconds, then replace the battery and turn it back on again.
Plantronics Explorer 360 User's Guide
The headset will automatically pair with the last device that it was paired with. You may want to remove that just in case. I am sending the users guide along with this. Also always start with the blue tooth turned off, the pass key is 0000 (four zeros).
Plantronics Explorer 300 Series User's Manual
If you've gone through the turning on process without success, then to paraphrase Dr. McCoy (a.k.a. Bones), she's dead Terry. There are no special buttons to push or battery to remove. It's time to upgrade with a new headset.
Unfortunately the Plantronics Explorer 330 is an older Bluetooth headset and the internal battery is probably just wearing out. Take a look at the Plantronics M20 (see link below), it would be a good replacement headset.
Plantronics... | Answered on Nov 22, 2011
It may be feed back from the surround sound or speakers in your home, car etc. Try sitting away from them. If that does not work, delete from your cell phone and re-pair back to your phone. Hopefully that will help.
On page 5 of the attached user guide for the Plantronics Explorer 300 series headsets (see link below) you'll find the instructions on how to shut your headset off.
Plantronics Explorer 300 Series User's Guide
On page 6 of the user guide for the Plantronics Explorer 300 series headset (see link below) you'll find the pairing instructions.
Here is a link to the users guide for your Explorer 330 Bluetooth headset. Look at the pairing instructions and make sure you are following them correctly.
Plantronics Explorer 330 User's Guide
Here is the users guide for your Explorer 330 Bluetooth headset:
The passcode for all Plantronics Bluetooth headsets is four zeros (0000).
Plantronics... | Answered on Nov 21, 2011
See page 6 of the Explorer 330 user guide for the correct pairing instructions. Link included below.
Good luck from Headsets DIrect!
Plantronics... | Answered on Nov 03, 2011
Not sure which Palm Treo you have, but after reading through some of the info on the different sites it states that some bluetooth devices were easily installed and others were not. It may be one of the Treo's that may need an application to download an update. Some of these were released according to the information I read, that did not have DUN installed. Whether this has anything to do with pairing your bluetooth device, I am not sure. I couldn't find a spec page for your application. Usually it is just a simple matter of going to the bluetooth application on your phone and turning on your bluetooth headset. They find each other and you have success. I would recommend talking to Plantronics tech help line at 800-544-4660 x 5538.
Plantronics... | Answered on Nov 02, 2011
It sounds like something in the control panel on your computer, Go into the sound settings and pick your device.
Below is the link for Explorer 300 Series User's Guide.
Plantronics... | Answered on Oct 26, 2011
This may be a broken or loose wire in your headset that prevents you from hearing them.
Or the headset is not turned on. Press the call control button for 2 seconds until you hear a beep or see the indicator light glow blue to turn headset on. Your headset is out of range. Move the headset closer to the phone or Bluetooth device.
If your phone has the voice capability's then you should be able to use it through your headset. If this was a plan you were using before a free app where it could be commanded by voice maybe it is over. However if your headset simply is not working I would try to return it the retail place of purchase if it is still under warranty, if not you can always talk to Plantronics tech at 800-544-4660.
Plantronics Explorer  330 Headset Logo
Popular Tags
123 questions posted
Top Plantronics Radio Communications Experts
Anthony Ward
Anthony Ward
gggg
edward80
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
View Most Popular
  • Plantronics Radio Communications
Most Popular Question
re plantroncs 330 headset seems lose
  • Radio Communications
