CI have a Phillips Hostess executive trolleyType HO 109MH. The electricity goes to the trolley red light is on but no heating to top and bottom sections of trolley.
A Pillips HO 109 hoetess trolley indicater lihts show on, but no heat,I have removed PC card but do not know how to test card,also how to remove elements and test. many thanks.A Pillips HO 109 hoetess trolley indicater lihts show on, but no heat,I have removed PC card but do not know how to test card,also how to remove elements and test. many thanks.
You can't post conmments that contain an email address.
Your wiring diagram and parts schematics are here in the link below. Normally the bottom element does glow read hot after a couple of minutes. Broil elements last a lot longer because they aren't used as much. There is only one Control Board. If I was guessing, I would say the temperature sensor is at fault. Elements either work, or they don't, but you can easily test continuity with a meter. Many parts are discontinued.
Yes two red flecked on same terminal and the black flecked on the other side terminal of the element. Bobs your Uncle......HEAT! Make sure they are a tight fit. New spades if required.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
Here is a free video to help you with your cooker fan motor problems
and how to fix them
For all your free videos on appliance repairs remember to
mark us down and leave feedback please
For all your parts visit our site http://www.apart4u.co.uk
Hi, If your electric oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself... Check out this tip that I wrote about the Oven not heating problem..
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Most modern
gas ovens and many broilers use a "glow-bar" style of igniter that
glows red-hot to ignite the gas. If the igniter doesn't reach the
proper temperature, the gas valve won't open. You may need to replace
the igniter.
