20 Most Recent GE JKS05 Electric Single Oven Questions & Answers
2answers
Stove smokes when i turn the oven on
on the oven's smooth surface you should use a razor blade and scrap off the plastic (when cooled).. if the plastic melted on the burner, you may need to replace that particular element from a local appliance part store. easy to do.
12/18/2014 2:44:35 PM • GE JKS05... • Answered on Dec 18, 2014
0answers
Start button does not work
As with all 240 volt appliances... if one breaker pops... you can't see it because it is a double breaker. You have to shut it down then turn it on. Ask again if it still doesn't work.
10/21/2013 12:15:00 AM • GE JKS05... • Answered on Oct 21, 2013
manual
manual
0answers
I get a f3 code
Be the first to answer 3/30/2013 11:58:29 AM • GE JKS05... • Posted on Mar 30, 2013Be the first to answer
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
3/20/2013 10:34:29 PM • GE JKS05... • Answered on Mar 20, 2013
A F8 is showing on our control pad...Help
Component failure within Electronic Range Control (ERC) effecting temp processing circuits. Replace the ERC. Here is the part to order.The part comes with a 365 day, any part, any reason return policy.
12/4/2012 6:23:39 PM • GE JKS05... • Answered on Dec 04, 2012
My oven will shut off while cooking, it's like it loses all power
I have the exact same problem with my GE wall oven, my model number is JCKS05BA2BB. Is there a known fix?
12/1/2012 2:55:25 PM • GE JKS05... • Answered on Dec 01, 2012
326B1230P001 GE TrueTemp Black Oven Error Code F0
We had the same problem with our GE Tru Temp Oven and the fix worked like a charm! Thank you for posting this fix - you saved our dinner party!
9/15/2012 3:16:10 PM • GE JKS05... • Answered on Sep 15, 2012
2answers
Self cleaning oven instructions
Self cleans generally do a good ****on small messes in 2 -2.5 hours. Larger messes take 3. Leaving the racks in is okay...but they will likely lose their shiny appearance. Manuals are on the GE website.
1/17/2012 10:03:28 PM • GE JKS05... • Answered on Jan 17, 2012
Eror f7 appears and a
An error F7 on this model means there is an issue with the touch-panel. It might need to be replaced even if the error is intermittent. The ERC (an electronic clock controller) might also have issues by can diagnosed further if replacing the touch-panel doesn't completely solve the issue--however, it should.
2/28/2011 5:11:14 AM • GE JKS05... • Answered on Feb 28, 2011
GE free-standing electric range Pre-heat oven
We have a new GE Range and the signal beeps at about 100 degrees below the temp which we have set . The dealer replaced the sensor and the control circuit, but there was no change.
A service tech from GE came to our house and explained that the new ovens have a bottom heating element which is covered and therefore heats the lower part of the oven more slowly; but the exposed upper element heats more rapidly and the sensor is located near the upper element. We were advised to wait for about 15-20 minutes after the beep before placing the food in the oven. Judging from the number of comments found online, this seems to be a feature of newer ranges.
SnapDoc
1/28/2011 1:16:12 AM • GE JKS05... • Answered on Jan 28, 2011
My oven cooks everything on the top, but not as
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
1/6/2011 2:48:43 AM • GE JKS05... • Answered on Jan 06, 2011
When the power is turned on to the oven, it starts
YOU NEED TO REPLCE THE ERC KNOWN AS THE CONTROLL CLOCK
12/22/2010 7:07:36 PM • GE JKS05... • Answered on Dec 22, 2010
GE JKS05 Electric Single Oven Logo
85 questions posted
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
View Most Popular
GE Ovens
  • GE Ovens
Most Popular Question
326b1230p001 ge truetemp black oven
  • Ovens
