20 Most Recent Belling XOU592 / XOU593 Electric Double Oven Questions & Answers
Diplomat adp 0511 grill has no gas or ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop. Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system. I offer free advice bcuz God is so good! GAS OVENS The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper). 2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit). 3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet). spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module. Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger. If it would not fix the problem, replace the bake burner and the igniter. There is a small chance for the spark module itself to be bad as well. The oven safety valve (also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
5/3/2015 6:22:22 AM • Belling XOU592 /... • Answered on May 03, 2015
Only one grill element works
Surface burners are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter. You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals. On modern electronic control ranges, the oven temperature sensor is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test. The infinite switch on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch. 1.If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons. (Locate the suspect switch for testing. Label all wires and terminals before disconnecting. A close up digital photo may be helpful. 2.On the burner control switch the terminal labeled "P" leads to the burner indicator light. The terminals labeled "H1" and "H2" lead to the burner element and the terminals labeled "L1" and "L2" (sometimes "N1" and "N2") are the power supply wires. 3.Set your multimeter to ohms setting x1. Turn the burner control to the highest temperature setting. Place one probe on pin "L1" and the second probe on pin "H1". The resistance measurement should be very low, zero to twenty ohms. If the test shows high or infinite resistance, the burner switch is defective. 4.Repeat the step above for the terminals "L2" and "H2". 5.If the control passes that test, turn the temperature setting to about the middle of the range and repeat the previous two steps. This will test for an intermittent problem with the switch. If the test does not show continuity with very low resistance, the switch should be replaced. 6.With the switch turned to the "Off" position, the resistance on each of the pairs of terminals tested above should now show no continuity or a reading of infinite resistance. 7.A test for continuity between "P" and "L1" when the burner control switch is on should show continuity. The light should be on whenever the control is turned on. If your test shows continuity, but the light does not operate, it is likely the bulb has failed. If the burner switch shows high or infinite resistance, the switch is not passing along current to the burner and so the switch should be replaced. ) Most modern ovens use an electronic control board to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced. The oven burner igniter commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced. : I offer free advice bcuz God is so good!
5/3/2015 6:10:44 AM • Belling XOU592 /... • Answered on May 03, 2015
The grill keeps going off unexpectidly, any tips out there anyone?
Oven comes on and off intermittently or heats very little: If the timer feature is activating and you have not touched the timer button at all, this would have to be a failed Electronic Oven Control. The timer button is either shorting at times or closing on its own from heat or moisture. The Electronic Oven Control would need to be replaced to repair the problem. Or Why does it take the oven so long to bake? When the food is taking way too long to bake, it's probably a weak bake ignitor. Replacing the ignitor usually fixes this problem, but you probably want to verify that the ignitor is the problem before replacing it. Sometimes the oven thermostat or oven sensor can be calibrated wrong, or it may be faulty. If your particular range has an oven that uses an electronic thermostat, and the oven temperature is off by tens of degrees, you probably have to replace it. On most units that have a mechanical thermostat, you can actually remove the thermostat knob, and adjust the knob to more accurately represent the actual setting of the thermostat. On many models, there's a screw on the back of the knob with a small calibration plate or ring. You can loosen this screw and adjust the calibration plate. Remember to tighten the screw again. If yours isn't adjustable, and the temperature is off by a large amount, you should just replace the thermostat. Or Oven safety valve needs to be checked with multi meter ohms / voltage ALSO Test the Burner Heating Element The stove's burner heating element is a coil of metal sheathed in an insulator. Electrical current travels through the element. Resistance to the passing of electrical current causes the element to heat up. A precise temperature cannot be set for a burner, instead it is turned on and off repeatedly by the control to the achieve an average temperature. When it is set to a low temperature, the element is cycled on and off more frequently. For high temperatures, the heating element is energized longer with fewer on and off cycles. Some burners have two elements, with the second only being used only for high heat settings. Before testing the heating element, unplug the appliance or shut off the power at thefuseboxorbreaker panelto avoid an electrical shock hazard. When a burner does not heat at all, or only heats up to a lower than expected temperature, the problem is likely to be with the heating element, the temperature control switch, or the wiring. If it only heats at the highest temperature, the problem is with the control or an electrical short, not the burner. If the burner works only intermittently, the problem is likely in the wiring or connectors. To test the heating element, try the following steps. First, disconnect the heating element from the stovetop. In most cases, this is done by lifting up the burner on the side opposite of the terminals (the part of the burner that disappears under the stovetop). Remove the decorative ring. Inspect the style of connection. If the burner element has visible blades that fit into the receptacle block, pinch the block with one hand, and pull the heating element free with your other hand. If the terminal block clamps over the element, the housing must be removed and the burner wires disconnected. Unsnap the metal piece or remove the screw that secures the receptacle block and then disconnect the element. Inspect the heating element. If you find bubbles, warping, or damage to the insulation sheath, the burner must be replaced. If the terminals are dirty or corroded, this can cause poor temperature control, intermittent problems or complete failure to heat. Clean the terminals with steel wool or very fine sand paper to restore good conductivity. Test theresistanceof the heating element using amulti meter. Set the multi meter to the ohms setting X1 and touch one probe to each of the terminals. A normal reading is typically somewhere between 20 and 120 ohms. The exact reading differs by manufacturer and mode. If the meter reads infinite resistance or the other extreme of the scale, zero resistance, then the element is damaged and should be replaced. If the measured resistance differs significantly from the expected range, the element is probably bad, but if possible, determine from the manufacturer what the actual resistance should be. To test for a grounded or shorted element, touch one probe to the surface of the burner and the other probe to each terminal in turn. If you get continuity at any time, the heating element is defective and should be replaced. The reason for my free advice is GOD is good!
5/3/2015 6:05:21 AM • Belling XOU592 /... • Answered on May 03, 2015
How do i fix the timer for delayed start
Strangely in all of this, u don't tell the oven when to start - it works it out itself! First u need to set the length of cooking time, eg 2hrs. Press the cooktime button(2nd one along), THEN use the +/- buttons to set the display to 2.00. THEN press the readytime button (3rd one), and use the +/- buttons to set the end time.eg 1730hrs The display should then revert to the present time. THEN turn the oven control to the required temperature. The oven will switch on at 1530 hrs. If u were to press the cooktime button ONCE WHILST the oven was on - it will display the cooktime remaining. AT 1730, the oven will switch off and the alarm will sound To switch off the alarm, press the minuteminder button - first one - looks like a bell, THEN REMEMBER to cancel the programme by pressing buttons 2 and 3 TOGETHER, otherwise it will do it again tomorrow! HOPE THIS HELPS I would suggest first.trying it when you're at home all the time the oven is on.
9/8/2014 12:16:21 PM • Belling XOU592 /... • Answered on Sep 08, 2014
Bottom oven and top oven
does the grill work? even if it does you need an engineer. the cooker will need to come out of the unit and the wiring and controls will need to be checked.
7/16/2014 7:07:45 PM • Belling XOU592 /... • Answered on Jul 16, 2014
0answers
0answers
0answers
2answers
Diplomat Double oven bottom oven fan works but
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
11/23/2013 12:05:11 PM • Belling XOU592 /... • Answered on Nov 23, 2013
Belling XOU594 Electric Double Oven Manual
Now on sale on eBay
3/3/2013 6:54:45 PM • Belling XOU592 /... • Answered on Mar 03, 2013
0answers
2answers
Dead oven despite element replacement?
If it has a timer, then make sure it is set to manual, and not auto, otherwise the oven will not come on.
What usually happens is, if you have a power cut, or switch the oven off, then the timer automatially goes to auto when the power is on again.
Please rate my solution.
Thankyou.
12/21/2012 10:19:37 PM • Belling XOU592 /... • Answered on Dec 21, 2012
Main oven works on full power whatever you set it
Hello,you need to replace thermostat
Thanks
5/6/2012 11:46:12 AM • Belling XOU592 /... • Answered on May 06, 2012
Belling XOU592 / XOU593 Electric Double Oven Logo
84 questions posted
Top Belling Ovens Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
David Spradling
David Spradling
Are you a Belling Oven Expert? Answer questions, earn points and help others
View Most Popular
Belling Ovens
  • Belling Ovens
Most Popular Question
grill keeps going off unexpectidly any
  • Ovens
