20 Most Recent Tecnik TKC8522 Electric Double Oven Questions & Answers
2answers
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
11/14/2014 2:07:25 PM • Tecnik TKC8522... • Answered on Nov 14, 2014
2answers
Tecnik TKC 8522 or 8525
hi if you contact tecnic should be in the manual they should be able to supply you with a new facia for the cooker good luck.
9/19/2012 10:16:26 AM • Tecnik TKC8522... • Answered on Sep 19, 2012
2answers
TKC 8522/2 top oven outer door shattering
It is not a fault with the door, and this sort of event occurs quite often, so is not uncommon.
All sorts of things can cause this, sudden change in temp, getting the glass wet whilst it is still hot, a knock or bang form an earlier time could have weakened the glass.
The list is quite long..
Depending on your household insurance, some policys cover for breakage of glass fittings, would be worth checking.
Plz rate my solution
.Thanks.
2/10/2012 10:14:04 PM • Tecnik TKC8522... • Answered on Feb 10, 2012
Delate button
TEST
5/26/2011 8:50:31 PM • Tecnik TKC8522... • Answered on May 26, 2011
My buttom oven is not working but top is working
If it is a fan assisted oven, and the fan is working, then it is likely to be a faulty heating element.
This should be located behind a removeable cover at the rear of the oven compartment.
If the fan is not working as well, then could be a faulty thermostat, even without the element or fan not working, there should be an indicator light on to show that the power is on,
Also make sure the main oven is set for manual operation, and not set on auto, as this will prevent the main oven coming on if it is.
2/12/2011 12:50:50 PM • Tecnik TKC8522... • Answered on Feb 12, 2011
2answers
Cant reset the clock
Press the cook time & ready time buttons simultaneously and keep the buttons depressed. use the plus and minus buttons to set the time of day. A (Auto) symbol goes out, cookpot symbol comes on.
1/27/2011 3:53:48 PM • Tecnik TKC8522... • Answered on Jan 27, 2011
I have a Tecnik TKC
If the red light does not come on, then this suggests that the oven thermostat or control switch is fault.
Even if the element was faulty, the red light shuld still come on.
9/25/2010 5:18:35 PM • Tecnik TKC8522... • Answered on Sep 25, 2010
Basic controls Tecnik tkl 925
here is a link to instructions. https://www.manualslib.com/manual/769358/Tecnik-Tkl-9290.html#manual
3/3/2024 2:24:57 PM • Tecnik Ovens • Answered on Mar 03, 2024
Program selector will not move
If the program selector on your Tecnik 2677 appliance will not move, it could be due to several reasons. Here are some possible causes and solutions:
  1. Obstruction: Check if there are any obstructions, such as food or debris, that may be blocking the program selector. If so, remove the obstruction and try moving the selector again.
  2. Loose or damaged parts: Check if any of the parts of the program selector or control knob are loose or damaged. Tighten or replace them as necessary.
  3. Mechanical issue: If the above solutions do not work, there may be a mechanical issue with the program selector mechanism. In this case, it is recommended to contact a qualified appliance repair technician to diagnose and fix the problem.
3/13/2023 4:54:57 PM • Tecnik Ovens • Answered on Mar 13, 2023
I need the Manual for the Tecnik TKC 1285 Dual Fuel Kitchen
You can find the manual for the Tecnik TKC 1285 Dual Fuel Kitchen online. You can search for the specific make and model of your kitchen to find the manual. Alternatively, you can contact the manufacturer of your kitchen to request a manual.
1/29/2023 8:27:55 AM • Tecnik Ovens • Answered on Jan 29, 2023
Tecnik TKC8525 manual knob symbols rubbed off
https://www.manualslib.com/manual/654296/Tecnik-Oven.html
5/30/2022 7:53:56 AM • Tecnik Ovens • Answered on May 30, 2022
Tecnik TKC8522 Electric Double Oven Logo
24 questions posted
Top Tecnik Ovens Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
ADMIN Eric
ADMIN Eric
Are you a Tecnik Oven Expert? Answer questions, earn points and help others
View Most Popular
Tecnik Ovens
  • Tecnik Ovens
Most Popular Question
tkc 8522 2 top oven outer door
  • Ovens
