Washing Machines Logo
Posted on Feb 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Hoover Elite 1210 toploading washing machine seems to make a horrible off balance sound on the spin cycle - even when there is a small load on. What can I do to fix it?
Gerry Harvey
Level 3:
Genius:
  • Hoover Master 1,482 Answers
  • Posted on Feb 09, 2011
Gerry Harvey
Hoover Master
Level 3:
Genius:
Answers
1482
Questions
0
Helped
379224
Points
4533
Could be bearings or more likely the concrete weight at the bottom of the drum is loos give it a shake from under to check...Good luck
Why does it always become unbalanced in spin cycle?
Kenmore Elite Top Load Washer - Unbalanced Loads ...
www.shopyourway.com > Manage My Life > Questions
Recently, the "LF" code has started to display and the soak cycle will not complete unless I ... Kenmore Elite Top Load Washer - Unbalanced Loads During Spin Cycly ... Would a bad outer tub literally cause the basket to become unbalanced?
Fix Unbalanced Top Load Washer - YouTube
? 1:21
https://www.youtube.com/watch?v=cVZIGhULzg0
Jan 17, 2014 - Uploaded by Carpe Diem
How to fix unbalanced high efficiency top load washer. ... I am having a MAJOR problem with unbalanced ...
Off Balance load in spin cycle - Sears ... - YouTube
Why does my kemore elite always get out of balance when spinning worst with a light load
When Loading, Always Distribute Clothes Evenly (weight wise) With A Light Load Usually Clothes Will Become On One Side Before End Of Wash Cycle--If You Look Before Spin Cycle And This Had Happened, Redistribute and restart from present position (cycle wise)
My washer makes a horrible noise in the final spin cycle on all washes
does ur washer shake & move also? if so, it may be that the loads r too small. especially with top loaders, when the machines not full, the clothes r not evenly distributed and that could do it. if u stop the cycle and evenly distribute the clothes, it should stop. hope that helps.
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
1helpful
Bad vibration during spin
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
Hoover elite 1210 won't progress to the final 'spray and spin dry cycle'.
Hoping to be of help after the spin dry wouldnt work on our hoover elite 1210.
It would do the wash cycle fine but as soon as it needed to drain, it wouldn't.
My handy man (Husband) is great at fixing things and opened the front panel by undoing the screws.
Near the motor on the bottom left, there is a wheel/fan looking thing.
(Turn the machine off first)
He tried to spin the wheel but it would only move clockwise and not anti-clockwise like it is supposed to.
So he gave the fan a few spins clockwise before giving it a gentle pull outwards in which it loosened the wheel and was able to move anticlockwise again.
We then turned the machine on and it started spinning and draining the machine.
This machine is a work horse and I refuse to get another. They don't make them like they used to!!
Mine has a leak and we use a drip tray underneath at the moment. So long as it works. I am happy.
Hope this helps someone else with the same problem.
Balancing
This type of thing should not be required. Front load washing machines (well, topload too i guess) will balance themselves out for the spin cycle unless the machine is grossly overloaded.
Good luck.
Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Machine not spinning due to uneven load balance although clothes are loaded evenly initially
I suggest you stick to the maximum load capacity (or less) of the machine; and not over-load the machine with clothes.
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
