Turn on the projector
press MENU (as show in picture step by step)
use down arrow key and select SETUP
press ENTER
use down arrow key to select LAMP SETTING
press ENTER
menu screen below will be appeared.
ON SCREEN display
setting for lamp replacement
Has the projection lamp been replaced?
YES NO
Select YES with left arrow key (yes is preselected)
press ENTER
ON SCREEN display
lamp replacement process is now complete
press ENTER
now exit the MENU with menu key and check the lamp timer
SOURCE: Reset Timer Lamp Sony VPL-HS60 projector
To reset the lamp timer:
1) With the projector plugged in and turned off, press the 'ON/STANDBY' button to put the projector in 'STANDBY' mode. NOTE: You have to press the button on the projector itself, you cannot use the remote for this step (this is not clear in manual).
2) Now, using the remote, press the following keys in order: RESET, <--, -->, ENTER.
3) Timer should now read '0'.
SOURCE: reset the lamp timer on PJ506d
Here's the manual
www.aboutprojectors.com/pdf/viewsonic-pj506d-manual.pdf
On page 24 in 'Advanced Mode', it tells you how to re-set to factory settings, and that will probably include zeroing the lamp hours.
If not, there seems to be nothing else there.
According to the manual, you need access to the RESET button, the left and right arrows and the ENTER button to clear the counter. Press the following in order for less than 5 seconds each:
RESET
Left Arror
Right Arrow
ENTER
The above sequence should clear the counter.
Dan
SOURCE: How do you reset the lamp timer for a sony Bravia
Go to link below on page 55 through 57 tells you how to replace lamp and reset timer.
http://www.projectorcentral.com/pdf/projector_manual_3674.pdf
3 Select "Yes." You will receive a message onscreen saying, "Lamp Timer Reset Complete!" Select "Yes" again, and press the "Enter" button to finish.
