Casio FX9750GII Graphic Calculator Logo
Posted on Feb 06, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't find the combinations (nCr) button on the fx 9750G11 calculator
k24674
Level 3:
  • Casio Master 8,093 Answers
  • Posted on Feb 12, 2011
k24674
Casio Master
Level 3:
Answers
8093
Questions
0
Helped
4675756
Points
21596
In Run screen, enter the number whose factorial you want to calculate ( number can be at most equal to 69), press [OPTN][F6] to get to next page of menus.
For factorials
  • Press then [F3](PROB) then [F1] (x!) followed by [EXE].
For combinations
  • Press then [F3](PROB) then[F3][nCr][EXE]
For permutations
  • Press then [F3](PROB) then[F2][nPr][EXE]
HOW DO I DO A FACTORIAL PROBLEM
Turn calculatorOn.
Press the Menu button.
Press 1 for Run screen
Press OPTN
Press F6>
Press F3:PROB
Enter the number whose factorial you wan, then press F1:x!Note that the number must be less than 70.
For combinations and permutations, use F3:nCr, or F2:nPr
Where is thecombination and permutation button
Combination are calculated using the nCr key. For Permutations use the nPr key.
How can I calculate combinations with fx-991ES PLUS?
Use nCr (the shifted function of the divide key). For example, to find the number of combinations of five things taken three at a time, press 5 SHIFT nCr 3 = and see 10.
Use the combination function. It's the shifted function of the divide key, marked nCr. For example, to find the number of combinations of 9 things taken 3 at a time, press 9 SHIFT divide 3 = and see 84.
Combinations on fx-991ES
Press [SHIFT][ division key]. It is marked with nCr.
Fx 9750g11
Please read the manual of the calculator. When you go from a scientific calculator to a graphical one there are some simple functionalities that are dropped. If you have any inequalities to solve use the graphing feature. Your solution set will be shaded.
4helpful
Where is the math button on the casio fx-9750G11
It is a calculator and prqactically every button is a MATH button. It depends on what MATH you intend to do. Put the calculator in Run/Mat screen then press the OPTN key. You will see several tabs. Press the function key under a TAB and explore what is offered. Go through all the keys (F6 also) and see what the new tabs do.
In general it is most helpful to read the manual that shipped with the calculator.
19helpful
2answers
How to solve for a factorial problem on a casio fx-9750g plus or buttons to press to get the ! how to solve for a combinations problems on a casio fx-9750 plus
There is no button but a menu tab.
For factorials
For combinations
For permutations
5helpful
3answers
Binomial function in calculator fx-911ES
The binomial probability distribution is defined as
P(r;p;n) =(nCr)(p^r)*(1-p)^(n-r)
where n is the number of trials, p the probability of success, and r the expected result.
Let n=20, r=7, p=0.15 ( I do not know wether this exemple has any meaning in the context of your problem, but you have to enter values that mean something to you. I am only showing you the key strokes
To enter 20C7 you press 20 [SHIFT][nCr]7 ;
To enter 0.15 to the power 7 you type 0.15[X to ] 7 the key is between
[x²] and [log]
To enter (1-0.15) to power 20-7, you type 0.85 [X to] 13
With [*] standing for multiplication key , and [X to] the raise to power key, the exemple above can be entered as
( 20 [SHIFT][nCr] 7) [*] ( 0.15 [X to] 7 ) [*] ( 0.85 [X to] 13 ) [=]
Here is a screen capture to show you what it looks like. However on this calculator the combination 20 [SHIFT][nCr] 7 is represented as nCr(20,7).
Hope it helps
12helpful
2answers
Combinations and Permutations
You can enter combinations and permutations.
If the order of the selection matters (ie. 1st, 2nd, and 3rd place out of 40 contestants) use permutation. Enter:
40{shift}{nPr}3 and then [=] for your answer set (=59280 possible ways).
IF order doesn not matter (ie. a team of 3 from 40 possible members) then it is a combination. Do the same as above, but substitute {nCr} for {nPr}. (= 9880 possible ways).
For your question: a three-digit set, selecting from 0-9. There is no specified order, it is a combination. The total n=10 (there are 10 digits in the range 0-9) and you are selecting 3.
so.... 10[nCr]3 with give the number of possible combinations.
Top Casio Office Equipment & Supplies Experts
k24674
Arnie Burke
Arnie Burke
Ngoro
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
