Wire as per the diagram:
I thought your amp hase ony one channel?!
If one channel connect like this:http://img203.imageshack.us/i/suzman701....
If you have two channel connect one speeker to one channel and other ond second channel.
Speaker on amp port, speaker - on amp - port!!!
The BAMF 5500/1D is a single channel amp. Connecting speaker wires as protuha suggests in his comment will cause protection to be activated on the amp and may even damage the amp. Connect as per the diagram only! (And as per protuha's original solution)
The sum total of the 2 speakers's max power should be 5500 Watt or more in the above configuration. If the total wattage of the speakers is less then speaker damage may occur at full power settings.
If you connect two speakers in serial way, resistance will be 2ohm and max amp power on 2ohm is 2500W(not 5000W as you say), so the speakers should be more than 2500w to prevent damage or don't use full amp power.
Yes you can connect but it needs to be serial not parallel connection. Because 1ohm is the smallest resistance for that amp, dont connect ++ on amp + and -- on amp minus port.
You need to solder and isolate + from one and - from other speaker, and connect + from one on + amp port ,and - from other on - amp port.
That way resistance will be 2 ohm and you can that way connect up to max 2500w speker power.
Hope i helpped.
Please write testimonial if I helpped you.
