Where the -tank, lines ,fuel ****? , o ring between carb body and bowel? is it running ok? if not and fuel is coming out of carb than your float and needle is stuck by gummy deposits. you will have to remove float bowel and gently pull down on float ,a good carb cleaning is in order ,might as well check main jet and others for blockage.SHUT OFF FUEL AND KEEP FUEL VAPORS AWAY FROM IGNITION SOURCES do not run it if you have a leak.
From where is the gas leaking?
