Computers & Internet Logo
Anonymous Posted on Jan 31, 2011
If you know about area formulas of class 8 and 9,please solve my question?there is a circle.in the between of the circle,there is a rectangle of dimension 4cm and 3cm.if the rectangle will cut out what will be the area of remaining portion?
Anonymous
Level 3:
  • Master 687 Answers
  • Posted on Jan 31, 2011
Anonymous
Master
Level 3:
Answers
687
Questions
Helped
232255
Points
1972
The diameter of the circle is the diagonal of the rectangle use Pythagoras this rectangle is a made from two 3,4,5 triangles, so the diameter is 5cm, the radius will be 2.5cm don't forget the BODMAS ordering rule (Brackets of Division Multiplication Addition and Subtraction) Also rounding to 2 decimal places. This solution is based on all four corners of the rectangle touching the circumference of the circle.
Area of a circle is P (22/7) i x Radius (squared ^2) ====> 22/7 x 2.5cm ^ 2 ====> 22/7 x 6.25cm
TOTAL AREA of CIRCLE = 19.64 cm^2
Area of the rectangle is length x width ====> 4 cm x 3 cm
TOTAL AREA of RECTANGLE = 12 cm ^2
The remaining portion is the circle area minus the rectangle 19.64-12 = 7.64 cm^2
SIMPLES brought to you by SpideRaY @ http://www.windowstipsclub.com
  • Anonymous Jan 31, 2011
    I thankyou if you like this solution please leave a testimonial and follow me @ www.facebook.com/windowstipsclub for more helpful advice and maybe a few more maths solutions.
The width of a rectangle is 2 meters less than the length. if the area is 120square meters, find the length and width.
Width is 10 metres
Length is 12 metres
Derive an equation for area in the form of x
Area= length x width
120sqm = x(x-2)
120sqm = xsquared - 2x
Then apply to formula for solving a quadratic equation.
Hope that helps.
Proactive IT Support PC Repairs Laptop Repairs Custom Built PC Leading IT...
If the diameter is 16 and the radius is 8 what do you do next?????
I am assuming you are looking for the most usual answer required by the measurements given.the simplest one is to find out the area of a circle once you know it's radius.
the formula is Pi x radius (squared) Pi is always constant so
3.1417 x 8 to the power of 2 OR 3.1417 x 8 x 8= 201.6 square inches.
2answers
2 to the 14th x 8 =
Use the [Y^x] key
2[Y^x]14x8=131072
Area of a solid rectangle formula
A rectangle is a 2D figure and is not a solid. Its area is the product of one side by the other side. Area =length*width.
Create a base class called shapes. use this class t store two double type values that could be used to compute the area of figures.dreive two specific classes called triangle and rectangle from the base...
Calculate area of triangle and rectangle. Get the values from the area function that is calculated by both classes then display that area using your own class.
2answers
A pizza is divided into 8 equal parts. what is the area of one slice if its radius is 6 inches?
Hello and Welcome to FixYa!
Area of pizza (Combined Bread + Crust) = Area=pie * (radius)^2. If divided in 8 equal parts, Area of 1 piece=Area/8.
Area= 3.1415* (0.1524)^2 Area of 1 slice= Area/8 Concerned.
Flowchart for inlementing a class circle in c++ which object of this class will represent a circle storing its radius coordinates of center as float. include a deffaulty constructor, access function, an...
Now if I give you the answer how are you going to learn anything about this? Your only asking for a flowchart. I will give you a hint. break the problem down. All the information needed except the Formulas used is in your post.
1helpful
How do i find asquare metre of a area what key do i use
Your field, terrain, figure has a particular form. For each form you have a formula that tells you how to compute the area enclosed. Read your book or your notes to know what formula to use. I cannot give you a formula because I have no idea about the shape of the figure nor its dimensions.
Now, having the formula at hand you can use your calculator to calculate the area. But, in order to obtain consistent values you must convert all dimensions to the same unit length: m, cm, km, inches, feet or what have you.
For example: You have a rectangle with LENGTH L=3.5 m, and a width W=20 dm (decimeters), you must convert the value in decimeters to meters, 20 dm=2 m.
The area of you rectangle will be
Area=L*W=(3.5 m)*(2 m)=3.5*2 m*m= 7 m^2
1helpful
In cpp programming why do we go for abstract base class?
Virtual keyword allows the program to dynamically decide which function to call. That is, when derived class is inherited from a base class the function in derived class can perform a completely different action from the one in Base class. Hence the function call via a pointer or reference maps to different functions based on the type of the object.
Abstract base class is used, so that anyone who is inherting from this class should implement that interface. Because the base class may not have a meaningful implementation for that interface. For example to design a program for computing area of different shapes like rectangle, triangle, hexagon etc. base class can be thought of as Shape. In addition the base class can be made abstract by declaring Area to be a pure virtual function. Then the different shapes like Rectangle, Triangle classes can inherit from Shape and implement Area interface based on their formulae.
Grand Canyon Tech
Grand Canyon Tech
