Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Perhaps you didn't see MY recommendation to prove your sub works. And explain how a "regular speaker wire" was used to prove it. If you don't want to answer the questions you won't get good feedback.
I don't do this for the money. I would have offered the same advice for free.
You are free to reject my advice if you want. I don't care. MY subs work.
as the last sentnce says the sub out on source is working. I know this because I hooked up a different sub to check source. So try again if you want to get paid ,because your last answer is wrong.
