20 Most Recent Onkyo TX-8511 Receiver Questions & Answers
This is a 2 channel stereo unit. Ebay shows @ a dozen of them for sale between $46- $90. In davenport Iowa, which isn't an expensive area, you can't touch a repair for that. Check your area Our estimate fee alone is $43
Onkyo TX-8511... | Answered on Dec 23, 2017
Hello. I am sorry about your issue. If the reset did not work then the receiver would need to be serviced. Thank you, Onkyo USA
Onkyo TX-8511... | Answered on May 05, 2017
The TX-8511 is an older AV receiver with only composite video inputs. Your DVD player may not provide this type of output as it's not capable of HD video. If your dvd player has a composite output with a Red, White & Yellow set of outputs, that will connect into the Video 2 inputs on the receiver. Your TV will need to connect up to the Video2 or Monitor output. You'll need a set of composite video cables with the red-white & yellow RCA type plugs.
Here is a link to the manual for this receiver:
Receivers Receiver Stereo Receiver AVR TX 8511 Onkyo USA
Onkyo TX-8511... | Answered on Dec 14, 2016
as follows to our chat session, please rank me for the solution..
Onkyo TX-8511... | Answered on Jan 22, 2016
I had the same issue... It turns out that there is light on the screen under the A and B speaker lights which said T-2 Monitor. This meant it was sending the sound out to the tape # 2 monitor... Hit the Tape 2 button and you are back in business...
Onkyo TX-8511... | Answered on Dec 01, 2015
Please contact our Parts & Services Dept at the number listed below during normal business hours Monday-Friday 9am-5pm EST ; or via email at parts@us.onkyo.com. They can be contacted at 201-785-2600, option # 4 for Parts & Services as they can further assist you regarding warranty and service issues. You will need to speak with the Parts & Services/ Warranty department for any servicing options or resolutions available for your issue.
Onkyo TX-8511... | Answered on Apr 17, 2015
You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1You can use a DS-A5 iPod docking station or a RCA Y-adaptor found at retailers such as APPLE, BEST BUY, RADIO SHACK, AMAZON, etc.: http://www.amazon.com/APPLE-COMPOSITE-AV-cable-ZML/dp/B004EWEX9Y/ref=sr_1_1?ie=UTF8&qid=1331155139&sr=8-1 . Connect from the headphone port of the iPhone and use the red & white RCA audio cables to connect into the RCA audio input terminals of your TX-8511.
Here you can get the owners manual for the unit if you need it; http://www.onkyousa.com/download/own_manuals.cfm?cat=Receiver For the protect mode to kick in only for some input sources, then there would have to be a fault in one or more of the pre-amp circuits - there will be a separate one for the radio tuner. Probably the solution for such a good unit is to contact the manufacturers and see what they have to say - probably they will suggest you send it in for service and i suspect they would be right - here are the contact details if you happen to be in the US; http://www.onkyousa.com/support/ or through this link if not; http://www.onkyo.com/ Hope this helps and you get an answer from them - it is probably fixable relatively easily and shouldn't be expensive for parts :)
Onkyo TX-8511... | Answered on Dec 28, 2014
Make sure you have not put it into tape monitor mode.
Onkyo TX-8511... | Answered on Dec 16, 2014
Go to the manufacturers web site to find the universal codes.
Only if the remote is universal.
Good luck
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
Onkyo TX-8511... | Answered on Apr 23, 2014
After finding the station press the memory button and then the station preset you want to save it to.
Onkyo TX-8511... | Answered on Nov 03, 2013
Onkyo TX-8511 Receiver Logo
89 questions posted
Popular Products
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Onkyo Audio Players & Recorders
Most Popular Question
hook up iphone 5s onkyo tx 8511
  • Audio Players & Recorders
