20 Most Recent
Celestion S10 Subwoofer Questions & Answers
I have a celestion s10 sub which the relay inside
I could have a good guess! What might be happening is that an IC is supplied with the audio signal which detects it and then switches a voltage to the relay. I should imagine this IC, which could be near the relay, has gone intermitant. It might have become heat sensitive, so a spray of Servisol Freezer Spray might cause it to work, proving it faulty. Follow the PC Board from the relay point to see where it goes to. It will lead you to the likely culprit(s).
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Clestion S10 Sub not working
Instead of connecting it to the sub output, try it on the L or R output of your amp.
This will eliminate the Denon.
If this fails, you need to test the loudspeaker driver unit whilst disconnected from the sub amp. Use a 1.5v cell (AA or bigger) connect using croc leads to the speaker's terminals. If the speaker is OK, you should hear a click. If you hear nothing, the speaker unit is faulty.
