20 Most Recent Velodyne CT-80 Subwoofer Questions & Answers
One of two things may be going on.
The amp has a fuse mounted on the PC board. The fuse may be blown.
The speaker may be bad. that may have blown the fuse.
You can test the speaker with a "D" battery.
Take the amp section out of the back, disconnect the speaker leads.
Touch the speaker leads to the poles of the battery. it should make a little thump and the cone should move freely.
Contact Velodyne for service.
Velodyne CT-80... | Answered on May 15, 2016
has it ever worked, if so did you ever use it in the cold because in the cold it is possible for the wiring inside the speaker to crack and break
Velodyne CT-80... | Answered on Jun 23, 2013
larryagross,
Sounds like you blew the speaker! The amp is sensing the voice coil is connecting to the speakers magnet or iron core and is going into a safe mode. It is possible to blow the coil even when the sub has a built in amp.
First make sure that you have the gains properly set ans not all set to their maximums. Second, disconnect signal to the sub then unplug the power for a few minutes. Third, plug the sub into a source of power on a different circuit using a surge protector.
Does the speaker make any popping at the time it powers up? If so you have a amp problem. If there is no sound produced, connect it back the the system using a different signal cable. Does the speaker now pop again when sound is produced. If so the speaker has failed. Contact a Velodyne repair facility.
-Chris
Velodyne CT-80... | Answered on Aug 13, 2010
The Q55 is not a velodyne product
Velodyne CT-80... | Answered on Dec 20, 2009
Not about Velo subs
cheak setting in sterio out put for sub on ect does woofer have sperk wire going in and out use them then ok
Velodyne CT-80... | Answered on Jan 03, 2009
Have you selected the appropriate input type? (e.g. Optical, HDMI?)
Some receivers (like my Onkyo 606) support HDMI passthrough, but will not decode audio signals from HDMI. Making it a pretty useless port!
Do you get sound when you select FM Tuner on the Pioneer?
Velodyne CT-80... | Answered on Dec 02, 2008
It sounds like you may have ripped the passive (the rubber material around the speaker that stretches when the speaker hits. If the passive is not ripped then it may be picking up static, or it could be blown. You can purchase a noise filter fairly cheap and try that.
Velodyne Audio... | Answered on Sep 30, 2019
You need to remove 12 outer screws, then remove the amp it might be held in with gasket.
There is a repair shop Edwards Electronics they are master's at repair. They are on web and eBay.
Velodyne Audio... | Answered on Aug 12, 2017
Sounds like you will need a new amp. Please send your serial number and the complete model number if it is different and I will quote a repair. Sales@speakerex.com
Velodyne Audio... | Answered on Dec 05, 2016
Replace all the greatest sized capacitors inside are deformed or leaking. can be a 6 pieces because some of them are used parrallell to get double capacity.
Velodyne Audio... | Answered on May 22, 2016
Velodyne CT-80 Subwoofer Logo
9 questions posted
Top Velodyne Audio Players & Recorders Experts
Steve Allison
Steve Allison
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Velodyne Audio Players & Recorders
Most Popular Question
connected subwoofer pre amp out
  • Audio Players & Recorders
