SOURCE: new needle for sony ps-lx250h?
I have the same turntable and I just bought a replacement needle through the needledoctor.com. The needle is made by Audio Technica and the part number is ATN3600L.
SOURCE: how do i replace belt on lx250h?
Not sure about yours, but some of these one lifts the rubber pad to get access to the belt through holes in the platter when you are re-installing to get the belt back on the hub it runs on. One usually has to lift the platter off to get the belt around the center hub and the motor pulley first..
You can probably find the belts online with a Google search.
SOURCE: the turntable motor runs but
most platters are secured with a c clip in the middle --gently prying it off should allow the platter to be removed--than a little dexterity is required to reattach the belt to the pulley and around the bottom of the platter--if the belt is broken or stretched you can pursue a replacement at mcm electronics .com
