Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Jan 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a F01 coming up on our machine. Any ideas.
Richard Roth
Level 3:
Top Expert:
  • Whirlpool Master 9,472 Answers
  • Posted on Jan 24, 2011
Richard Roth
Whirlpool Master
Level 3:
Top Expert:
Answers
9472
Questions
Helped
2629036
Points
28464
The "F01" error code is indicating a communication error between the Central Control Unit (CCU) and the EEPROM on board the CCU occurred.
Generally in order to correct this failure the CCU board will need to be replaced.
Reset innov-is 350 from f01 error
Copied from the user manual:
If error message "F01" through "F09" appears in the LCD while the
sewing machine is being used, the machine may be malfunctioning.
Contact your nearest authorized service center
Fix-ya
For this model it should say F01 because there is a difference between F01 and F11 need to know if 01 if you have F blank then 1 the light is out on the UI display if indeed it is 01 then service sheet points to a possible main control hope this helps
MAYTAG 3000 F01 CODE
It's probably a weak or failed component on the board. It's a common issue on those machines and the Whirlpool Duets. It's usually burned at the motor relay or heater relay.
F01 error code flashes when there is a primary control failure.
The only thing which will solve an F01 error code is a new machine control board. These is a catastrophic control board failure. Nothing can correct it. The part number you require is W10205977.
2helpful
2answers
Showing F01 error code on readout? what does that mean?
Hi.
It depends on the model. On Whirlpool built machines F01 is EEPROM error, pump drive error, or main relays error.
With Hotpoint F01 means defective triac or defective motor.
2helpful
Hotpoint WMD washing machineFault Code F01 machine will not start
Fault code F01 indicates a problem with the motor triac.
Check all connections to and from the motor, the control module, and the motor plug
HOW TO FIX A F01 ERROR ON MY DUET HLT WIRLPOOL WASHER
hi my name is joyce
Did you try to unplug the unit for 60 secounds and replug it back up?
do this and see if this works. then reset the machine's cycle, you are in the middle of cycle I usually push pause cancel and wait till the door beeps and then I can open it. but if this does not open the machine do the unplug and reset method. if this does not work please let me know.
thanks,
joyce
Hotpoint erorr f01
sounds like a faulty water valve regards jason
2answers
F01 flashes and machine not work.WF860P
motor triac short circuit check motor and module connections, if o.k poss motor fault
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
