There are 20 memory locations to store numbers in, they are numbered 01 - 20. Press and hold the memory button until Memory Store shows in the display. Dial the 2 digit memory location or use the arrow keys to choose the memory location. Press the select/channel button which will show Store Name in the display if the memory location is empty or will show edit and delete options if the memory location has an entry in it. If the memory location is empty, use the number keys to enter a name for the memory location. Press the select/channel button which will show Store Number in the display. Enter the phone number using the dial pad. Press the select/channel button to save the entry. Press the memory button to end.
Here is a link to download the manual in pdf format.
http://www.uniden.com/pdf/TRU348om_VA.pdf
