20 Most Recent Samsung Glyde SCH-u940 Cellular Phone Questions & Answers
How to unlock and factory reset samsung sch-r680
Typically when a mobile device is locked, it wants the original e-mail account name and password it was setup with. You shouldn't need internet connectivity to unlock the phone. If you can log into your account at https://mail.google.com/ that's good, but it doesn't guarantee it's the same account the device is using or the original password used. In some cases, if the device can receive a call, you can access the menu during the call and disable the screen lock. If you don't remember the username and the account was properly setup at creation time, you can recover the name using "I forgot my username" here: http://support.google.com/mail/bin/answer.py?hl=en&answer=46346 And here's a trick to recover an account name on an Android device: https://productforums.google.com/d/topic/gmail/ydNElvUjJVU/discussion If you have the username, the following will help with the process to recover the account by resetting the password: http://gmailaccountrecovery.blogspot.com/ BUT... A recovered account or changed password won't have the original password which is what the device needs to be unlocked. In that case the device will probably need to have a factory reset done (read the owner's manual for instructions) and then setup again with an e-mail account (be sure to write the information down this time). If it's setup with the recovered e-mail account, any purchased apps and synced data should be restored. If a new account needs to be created, all previous information will be lost. An article on this topic: http://einartysen.se/unlock-android-phone-after-too-many-pattern-attempts/
5/20/2019 2:39:15 AM • Samsung Glyde... • Answered on May 20, 2019
2answers
Samsung e1100 sim track jumper
samsung e1100 sim jumper problim
3/12/2019 1:10:32 AM • Samsung Glyde... • Answered on Mar 12, 2019
3answers
It says unable to charge non supported battery.
I got this message to on my samsung phone but after cleaning the ports with that air in a can stuff the phone charges and i never got that message again
8/4/2015 5:13:54 PM • Samsung Glyde... • Answered on Aug 04, 2015
How to fix a broken screen?or how much would it
I would suggest to contact the manufacturer or have a local tech to replace the broken screen because it's difficult to replace it.
The screen cost $99.95. Please check the link below:
http://www.cellulardr.com/GH07-01234A.htm
Thank you!
7/18/2014 5:34:54 PM • Samsung Glyde... • Answered on Jul 18, 2014
3answers
I DON'T know what is initial programming is?
initial programming occurs when your phone needs a second roaming based and if you accidentally change the NAM settings of your phone to NAM2. the default NAM settings of your phone is NAM1.
5/20/2014 2:07:15 AM • Samsung Glyde... • Answered on May 20, 2014
ZTE Z796C SAYS INITIAL PROGRAMMING REQUIRED
To activate your new pre-paid services after choosing a plan and paying for it is to dial the following number: *22890
5/20/2014 2:05:55 AM • Samsung Glyde... • Answered on May 20, 2014
S4 play store app quit working
I hope this help. Enabling background data Google Play requires you to enable background data in order to function properly. To enable background data and auto sync on your device:
  1. Press Menu from the home screen, then visit Settings snp_2918920_en_v1
  2. Under Wireless & Networks, select Data usage
  3. Tap the menu button in the top right corner
  4. Make sure "Restrict background data" is not selected and "Auto-sync data" is selected
Please note that on some devices, you'll find the background data option here: Menu > Settings > Battery data manager > Delivery > Background data.
3/23/2014 8:14:32 PM • Samsung Glyde... • Answered on Mar 23, 2014
3answers
My phone has the pop up that says
Is it asking for a code? if it does you need to provide the serial number of the phone for me to help you, if it is not asking for a code you need to call up All tel to reactivate your account.
2/23/2014 11:23:09 PM • Samsung Glyde... • Answered on Feb 23, 2014
0answers
5answers
Lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
11/3/2013 5:37:05 PM • Samsung Glyde... • Answered on Nov 03, 2013
Reset
Instructions
    • 1 Turn on the cell phone. If it's locked, use the current PIN number to unlock it.
    • 2 Navigate to the "Settings" screen, or to a screen of the same significance. Different phones will have different names for screens, but the security features are always available on the screen that allows users to change the settings.
    • 3 Open the "Security" menu. On this menu, you will probably be able to view your passwords and information about your phone, such as the email address you were given by your service provider and your phone number.
    • 4 Enter the menu that allows you to view and change your password.
    • 5 To change your password, you'll first have to enter your current password. You'll then need to enter your new password and confirm it. Make sure the new password is something you can easily remember. If you lock your phone and forget your password, you'll have to enter your phone's PIN Unblocking Key (PUK) or call your cellular service provider to get an unlock code, either of which can be a hassle.
God bless you
5/24/2013 4:26:19 PM • Samsung Glyde... • Answered on May 24, 2013
Earpiece dosen't work
The earpiece have to be replace but the problem is that you have to find one from another phone cz they don't make replacement part for that phone
But they do have the speaker on ebay
If you look little harder you will find the earpiece
12/27/2012 5:19:30 AM • Samsung Glyde... • Answered on Dec 27, 2012
Dont remember the lock on my phone
Dear Brother:ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will SolvedIf For puk & pin cod problem So PleaseVery Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office opratorEnter The Puk code and YesEnter The pin code and YesSo Puk code Open and Problem will Quickly Solved
12/7/2012 5:28:11 AM • Samsung Glyde... • Answered on Dec 07, 2012
Cant remember my lock
12/7/2012 4:46:56 AM • Samsung Glyde... • Answered on Dec 07, 2012
2answers
Samsung e1100t sim tray not
samsung e1100t sim tray not supplay.pls help me.
11/10/2012 4:11:29 AM • Samsung Glyde... • Answered on Nov 10, 2012
Samsung Glyde SCH-u940 Cellular Phone Logo
225 questions posted
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
SCH Samsung
  • SCH Samsung
Most Popular Question
samsung e1100 sim track jumper
  • Cell Phones
