Compaq Presario M2000 Notebook Logo
Posted on Jul 15, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Compaq presario M2000 power cord won't charge my laptop
I've had my laptop for a good 3 years and reccently after i got back from a trip. I had left my laptop at home and when i got back i used the laptop for a school assignments and when i tried to recharge the battery it won't work. At first i was able to charge the battery by messing with the power cord, but now it just doesn't want to charge the battery. Does this mean I need a new power cord for my laptop
  • Anonymous Mar 14, 2014
    my laptop does not charge i have the original cord that came with it and it used to charge i got a virus that caused me to have to restore it to factory settings using the laptops included restore/recovery partition The restore completed successfully At least that was the message displayed after it was done But from ten on it gives me the error message "battery plugged in but not charging" and will no longer operate without being plugged in and battery is always at 0%
Ekse
Level 3:
  • Compaq Master 13,435 Answers
  • Posted on Jul 15, 2008
Ekse
Compaq Master
Level 3:
Answers
13435
Questions
82
Helped
3985253
Points
38023
Check that your power adapter is working fine it may be that the power cable is broken somewhere between the adapter and the laptop. You could try another charger / adapter.
sreeradh p.r
Level 2:
  • Expert 87 Answers
  • Posted on Jul 16, 2008
sreeradh p.r
Expert
Level 2:
Answers
87
Questions
Helped
38478
Points
187
Please try this
First u remove battery from ur laptop and connect power adpter
check laptop power on
if laptop is working u will change laptop battery
otherwise u could try another power adpter
Compaq M2000 turns on using charged laptop battery but doesn't charge or turn on when using power adaptor, with or without the laptop battery
1) The AC adapter should ALWAYS be plugged into the laptop FIRST, then plugged into AC power. If not, this could create a voltage spike.
2) Let's look at the DC Power Jack, for the Compaq Presario M2000 series of Notebook PC's,
http://www.notebookparts.com/products/description.php?II=9741
The DC Power Jack is mounted to a removable circuit board.
Enlarging the view of the jack, shows us there is an Inductor.
The small 'can' standing up on the power board. This chipset could have gone south. (Bad)
How to know? Replace it, or dig out your dual trace oscilloscope. See if the Inductor works.
Could also just be cracked solder joints, of the DC Power Jack, TO that small circuit board. Solution would be to resolder it/them.
[ I WOULD however, search for a BETTER price, than listed in the link above, IF available ]
DC Power Jack is in good shape, soldered tight to the motherboard, and ruled out as the problem?
(Since you know the AC adapter is good)
Then the problem would be the Inductor on that power board, or power correcting chipset.
What one is it? Dunno.
DO KNOW is has J leads on the bottom.
CAN give examples, and perhaps you can identify using them.
1) https://docs.google.com/viewer?a=v&q=cache:oER5NNz8cwcJ:www.fairchildsemi.com/ds/FD/FDS6675BZ.pdf+Fairchild+FDS6675BZ&hl=en&pid=bl&srcid=ADGEEShOhWPjm_M-ROHme4iEMrztCTOd-28jNiy1hVLQQh_VOyv8zcXEVDB_iTQA6MuZO88UmRkDgjyW9j4CP2aIJ-4DS-h6JNM3lvxldeApQeecmz_DADCw1s7tmNLxfPknqX14SZP6&sig=AHIEtbS_rYUAeo_8rB9YHkW05ZjLqeH4Jg
2) http://www.utsource.net/ic-datasheet/KB926QFB1-1829416.html
Service Manual, (Free), for Compaq Presario M2000 series of Notebook PC's,
(Remember, follow Anti-Static Precautions. USE an ESD wrist strap, and connect it's alligator clip to a good ground source),
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Drop down to the line that begins with - Compaq Presario 1100.
(1100 in blue)
Scroll over, click on M2000. (In blue)
(Ignore if you are aware of the following;
PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name { M2000 }, it may take up to 30 seconds, before the first page comes up )
Compaq Presario M2000 series of Notebook PC's, disassembly guide,
http://www.insidemylaptop.com/take-apart-compaq-presario-m2000-notebook/
Regards,
joecoolvette
2helpful
"battery doesn t charge how do I know if the power cord or the battery is bad on my Presario M2000
If the battery is over a year old then it could be dead.Anything over two years I would bet on it. Usually the power bricks are very reliable. To check it you just need to put a power meter on it and check the voltage against what is printed on the brick. It should be slightly higher.
Without a meter it is pretty hard to check. You should get some indication that it is plugged in. It may have a power light on the brick or the laptop that shows it on even if it wont charge.
BATTERY IS BAD. CHARGE CORD HEATS UP. REPLACED CORD AND CHARGER LAST YEAR
Compaq chargers get heated up a lot when charging. This is a common problem.
Based on the issues you mentioned, unfortunately you would need to get the battery changed.
Regarding the charge cord getting heated up, try keeping it on a concrete/cold surface to lessen the heat. Unfortunately nothing more can be done about it, and as i said compaq chargers do get heated up quickly.
Thanks.
2answers
Turn on a s/h presario m2000 and it asks for a password of which i dont know what do i do`
try pressing esc. two times.
Or type admin for username or admin for password. Or try password for password.
2helpful
2answers
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
1helpful
2answers
Compaq M2000 laptop lighting bolt flash 3 times wont start
Could be a bad mother board or a hard drive..see if you can connect the hard drive with a USB on another machine and run a test on it...
Computer shut down
The sparking has probably caused your circuit protection inside the AC adapter to turn off the current.
Also, when you are plugging an adapter in,,do not have it plugged into the wall power outlet when plugging into the laptop,,,plug into the laptop first and then plug into the wall.
2answers
Computer wont come on
well, sounds like your power cord took a dump on you check and make sure power cord light is working first i would suggest
takeing up to office depo or computer store or maybe some one you has a lap like your try the power cord on it and see if it boots up that computer or takea differnt power cord and try reboot it they sale altn. power cords for laptops (cheaper in ebay ,ubid or just type in power cords in your search engine ). i hope this helps lala linda
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
