2001 Chrysler LHS Logo
Posted on Jan 09, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2001 Chrylser LHS. The battery is being drained when sitting overnight. Will not start in the morning! New Interstate battery has been tested and is good. Any ideas will be helpfull!!!!
Anonymous
Level 2:
Sergeant:
  • Expert 288 Answers
  • Posted on Jan 09, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
288
Questions
0
Helped
92322
Points
898
TO FIND OUT IF THERE IS A BATTERY DRAIN. TURN OFF ALL SWITCHES, MAKE SURE THE GLOVE COMPARTMENT IS CLOSING RIGHT & THE LITTLE LITE IS GOING OUT. OPEN THE HOOD. IF THERE IS AN UNDER HOOD LIGHT, REMOVE THE BULB, OR UNPLUG THE LIGHT.
CLOSE ALL DOORS TIGHT. WAIT 30 SECONDS AFTER CLOSING THE DOORS, LOOK THROUGH THE WINDOWS, ARE THE COURTESY LITES ALL GOING OUT ." THEY MAY BE ON A DELAY TIMER ". DISCONNECT THE NEGATIVE CABLE FROM THE BATTERY, PUT ONE END OF A 12 VOLT CIRCUIT TESTER ON THE NEG. TERMINAL OF THE BATTERY, PUT THE OTHER END ON A GOOD GROUND. IF THE CIRCUIT TESTER LIGHT COMES ON SOMETHING IS DRAINING. TO FIND THE CIRCUIT THAT IS DRAINING, YOU WILL NEED TO OPEN THE FUSE/RELAY BOX PROBABLY NEAR THE BATTERY. ONE AT A TIME PULL EACH FUSE OUT, UNTIL THE CIRCUIT TESTER LIGHT GOES OUT. WHEN IT GOES OUT READ OWNERS MANUAL TO FIND OUT WHAT IS IN THAT CIRCUIT.
2001 Ford Escape wont start in morning but starts after short jump and will start all day but not next day
test for a parasite drain https://shop.advanceautoparts.com/r/car-projects/battery-drained-overnight-how-to-fix-parasitic-power-loss
Bought new battery. morning vuka don't want to start. mornings I had to jump start it 0km still refuse to start on its own
Probably something draining the battery overnight. Interior light left on? The regulator in the alternator could be bad and keeping the ignition energized draining the battery. If your jump start it drive to work get off work and it starts after 8-9 hrs you have a system voltage leak some where. If nothing is left on overnight have the voltage regulator tested in the alternator.
Van battery is always dead in morning
The car is using power overnight, so that the battery has drained by morning. Make sure every light is turned off when you leave it.
Electrical problems,won't start in morning after sitting overnight,with boost it starts immediately
Have your battery load tested at auto parts store. Do it while still in the car. They can also check your alternator at the same time. It sounds like you either have a short that is draining the battery as it sits overnight or as your vehicle runs the battery has enough charge to run but not enough charge to last it UNTILL the next morning.
I HAVE A 2001 VW BEETLE.EVERY MORNING I HAVE TO JUMP THE BATTERY OFF.I CHANGED STARTER,ALTERNATOR IS OK.EVERY MORNING IT MAKES A CLICKING SOUND BEFORE JUMP IT OFF.
Have your battery load tested. It sounds like overnight it's slowly losing it's charge. Another possibility is something electrical is "on" or draining battery overnight.
2answers
I HAVE A 1994 CHRYSLER LHS THAT KEEPS SHUTING DOWN ON ME. THE BATTERY KEEPS DRAINING. IT HAS A NEW ALTERNATOR AND BATTERY WHAT ELSE COULD IT BE?
ECM.
Pull fuse # 3 from fuse box and charge battery.....leave vehicle overnight and see if starts in morning. I own 92 and ECM went out. Expensive to replace and has to be exact fit. My battery stopped draining after removing fuse!!!!!!!!!!!
My 95 lhs wont start in hot weather and stales out cold
Also replace the camshaft sensor and fuel filter.
'96 Chevy Tahoe won't start
i had similar problem. hard to start in morning but once started, would start everytime until next morning. i changed fuel pump, filter, fuel pressure regulator, coil, cap, rotor, pickup coil, battery. i was finally told the '96 had a recall on the fuel injection assemby. i changed that out with the new mpf system and it solved the problem. runs like a striped ape. hope this helps.
james bentley
Top Chrysler Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Chrysler Expert? Answer questions, earn points and help others
