Kirby Ultimate G Bagged Upright Vacuum Logo
Posted on Jan 08, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The wheels fell off. - Kirby Ultimate G Bagged Upright Vacuum
Anonymous
Level 2:
  • Expert 240 Answers
  • Posted on Jan 28, 2011
Anonymous
Expert
Level 2:
Answers
240
Questions
0
Helped
69623
Points
512
The wheels are held to the axles with small c-clips. Perhaps these have come loose. If the wheel is still attached to part of the axle. The axle has broken and will need replacement.
My wheel fell off where cani get it fixed
Those wheels have a fixed axil that goes bad. A new wheel will fix that.
Sep 05, 2014 • Vacuums
The wheel on my Dirt ***** vacuum fell off. I tried putting the wheel back on but now the wheel is loose.
Hi! We recommend you take your vacuum in to a Dirt Devil authorized service center for repair. We have included a link you may follow to locate the nearest service center to your zip code. Hope this helps!
Service Center Locator
G series kirby ultimate the wheel fell off and its on the side with the height adjustment....all fell on to floor when it came apart....how does that wheel stay on is there a part missing or do you just...
I cleaned the end of rod and the hole in the wheel, and then forced the wheel back on the rod. A little bit of glue at the end of rod will help to keep wheel stay.
When i removed the bottom panel to clean out the roller brush, the front wheels fell off. I can't figure out how to put them back on!
I( think Dirt devil wheels are held on by a little clip, kind of round ish. Check the other wheel and see if it has that kind of set up. Chris
My front wheels fell off how do I fix it. there is a slender long spring and I don't know where it goes
That spring connects to a slot beside the height adjuster knob and a hole in the base to the wheels that fell off.The problem is you can't get the wheels to go back in flush so the height adjustment works.The vacuum will not be close enough to the floor to get any type up suction or brush contact.To change that spring as well as the belt,remove the cover by taking out two screws,one on each side.Force the rller out by prying the right end out of the slot.
1helpful
Wheel and lever fell off Kirby ultimate G
the spline shaft is probably worn. you will have to replace the assy.
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
