Using a fog light kit ( wiring and switch) you can run the power of those lights to the switch, and the lights will only work when the switch is on. You can access the power line behind the lights on the driver side. only need 2 wires and the switch. take the positive wire and connect it to your wire going to the switch. Now the second wire is connected just before the lights after the first wire. you now have a simple on and off switch for the lights
Most of the time with a GM type vehicle to get the headlights off while engine is running and vehicle is in park you just have to put the parking brake on only a click or two. That or sometimes you have the ability to turn them off by the headlight switch which is normally turned to automatic. If you turn it all the way to the right it should turn them off.
