check thermostat setting. make sure unit is on! when u say "air will not kick on"? are you saying the heated air is not blowing out? if no hot air, there is no heat to blow out! fix furnace!
Plug in a ceramic 120 volt or oil type space heater to keep trailer warm. Most travel trailers are propane only, they do not have electric heat strips. I would bet that is why it only blows cold air.
You either have something wired wrong or you have a direct short in the system. Are you starting the A/C or the furnace? If it's the A/C, it could be a shorted compressor, capacitor, fan motor or it's wired wrong.
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
The doors that open and close in the heater control unit are ran by motors. It sounds like a motor has quit in yours. When turning on the defrosters the motor closes the door to the heat for the floor
This could be an inoperative condenser fan.System will kick off on high pressure without proper air flow.The hum indicates voltage is present. Providing the fan motor is not locked up and will spin,Check your run capacitor which helps boost the motor voltage initially and will get it turning.If the cap is good,you may be faced with motor replacement....good luck
