20 Most Recent Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU) Questions & Answers
Hi, new switch can be found on amazon... here: Amazon com Coleman air switch. I hope this was helpful. Cheers
Coleman Propane... | Answered on Jun 05, 2019
you might want to check the filter, if the filter is restricting the airflow the furnace will over heat and it will shut down. if you turn it off and on it will reset it and it will try again. Pull the filter out half way and try that, if it runs fine then clean the filter or get a less restrictive one.
Coleman Propane... | Answered on Feb 07, 2019
have someone check the gas presure most likely too high no more than 11
Coleman Propane... | Answered on Apr 16, 2018
You have a bad control board. Replaced the board
Coleman Propane... | Answered on Mar 13, 2018
I have 2 of these furnaces in mobile homes I own. On both of these the wheel inside the draft inducer blower that has the clear tube attached to it has a small wheel in it that over time tends to stick. Take the 4 screws out and give this little wheel located towards the bottom a push. Your problem may be solved without investing in expensive parts :)
Coleman Propane... | Answered on Feb 08, 2018
Fan control could be on summer switch. or af control not working keeping fun running
Coleman Propane... | Answered on Dec 13, 2017
You either have a bad thermocouple or you need to reset the burner control.
Coleman Propane... | Answered on Dec 07, 2017
You did not indicate the year or size of the mobile home, but, having lived in several in cold Michigan, here are some things.
Be sure all the windows are well sealed.
At first, I used to put a strong clear plastic sheet over the insides, and tape these in place.
Later, I bought foam insulation board at a lumber yard and cut pieces to fin the window openings, and taped them in.
When it is really cold, feel the walls, the floor, and the ceiling.
If you find cold to the touch, you are losing heat there.
If your floors are cold, put insulating panels and skirting around the bottom of the trailer.
If your extreme cold lasts for months, some people consider putting a small electric heater under the trailer that is temperature controlled.
Some people do a "roof-over" by setting poles or posts alongside the trailer and adding an additional roof above the trailer.
That step would enable you to add insulation above the top if your ceiling is cold.
God bless your efforts.
check gas pressure if too low will over heat and shut off
change spark plug and add small amount of starting fluid to breather pull with all settings in proper place if it is going to start it will or you have other problems
Coleman Propane... | Answered on Oct 11, 2017
do what ever you wish to do .
Coleman Propane... | Answered on Oct 05, 2017
make sure fan on auto
Coleman Propane... | Answered on Sep 11, 2017
compressed air or take apart and blow out also check gas pressure
check flame sensor
Flame sensor might need cleaning and check connections Also check pressure switch .
Coleman Propane... | Answered on May 07, 2017
BEWARE OF HIGH VOLTAGE! 220VAC CAN KILL YOU! That said, it sounds like you have a short in the control (24VAC) curcuit to the condenser. A mouse probably made a home in the control compartment of your condenser. BEWARE OF HIGH VOLTAGE! 220VAC CAN KILL YOU!
Coleman Propane... | Answered on Mar 24, 2017
its a car question
check the key fobs are the same for both years
and if you need a diagnostic scanner to code the keys or not
information says yes
any ignition barrel from kia sedona 1998 -2006
Coleman Propane... | Answered on Jul 15, 2016
there is a thermo-sensor switch next to the circuit board that tells the fan switch to turn on when the plenum is hot enough. this needs to be replaced.
Coleman Propane... | Answered on Jan 28, 2016
Heating & Cooling Logo
Popular Tags
373 questions posted
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Paul
Paul
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Coleman Heating & Cooling
Most Popular Question
furnace not cycling properly
  • Heating & Cooling
