20 Most Recent Coleman 10' X 10' Sundome Tent 9160K101 Questions & Answers
Clean the ground of any rocks, logs or big sticks. Open the stuff sack and pull out all of the contents. Pull the poles out of their pole bag and set them aside. Remove the tent stakes and set them next to the tent.
  • 2 Lay out the tent poles and assemble them. Push the rod blanks together to make the tent poles that will support the mesh tent body.
  • 3 Unroll the mesh tent over the cleared ground. Take care not to step on or walk on the mesh panels. Avoid sticks and snags, as the mesh rips easier than nylon tent fabric.
  • 4 Clip the Timbertop tent pole clips to the poles. There are no tent pole sleeves because Timbertop uses external pole clips for its mesh tents. Criss-cross the tent poles and push the tent pole tips into the metal holes at the end of the pole clip lines. The mesh tent will now be standing upright.
  • 5 Place one tent stake into the ground and through a pole strap stake hole. Pull the tent out as you insert the stake to keep the mesh panels tight. Stake down each pole strap around the perimeter of the tent. Unzip the doors to enter the tent. Zip up the doors quickly after entry to keep bugs and insects out of the tent.
  • Coleman 10' X... | Answered on Jan 11, 2019
    My Coleman has the same problem. I can crank the top up but it will not hold in place.
    I just leave the crank handle in place after raising the top and secure the handle to the bumper with a bungee cord. It's jury rigged but it works great.
    Coleman 10' X... | Answered on Sep 01, 2018
    sorry but we (fixya) can not help you FIX this contact the MFG or a retailer that sells them
    Coleman 10' X... | Answered on Apr 07, 2018
    go to the Coleman web page and down load a user manual for that model
    or simply talk to a Coleman tech representative to get the info
    Coleman 10' X... | Answered on Jul 08, 2017
    there is something in the jets or the piping to the mantels, you my find spider webing there, if you did no cap the port where the tank goes some small friends might have wanted to go camping with you.
    Coleman 10' X... | Answered on Apr 04, 2017
    HI,
    Sorry for my english, I,m french. I'm from Québec, Canada.
    I have the same problem with my fireplace. Same model.
    Do you have the manual or the papers who came with the fireplace. My electrician need it. May you scan or fax to me?
    Thank you very much.
    Jacques Blanchet
    Fax: 1-819-762-0130
    email: jacques.blanchet@cableamos.com
    Coleman 10' X... | Answered on Feb 07, 2017
    Kerosene lanterns require a little more than just lighting the mantles. Go to Coleman's website and find the directions (for free) for KEROSENE lanterns. The generator on the lantern needs to be preheated with alcohol before it will actually light. Make sure lantern is a Kerosene lantern and not a white gas (Coleman fuel) type, there is a difference even though they look similar.
    Coleman 10' X... | Answered on Dec 01, 2016
    If you go to www.coleman.com Use the product services link for product manuals. You can then choose tents. Or you can use this link:
    http://www.coleman.com/coleman/images/pdf/2000000136.PDF
    Coleman 10' X... | Answered on Nov 11, 2016
    Usual problems are:-
    No gas from supply cylinder.
    Safety bypass not allowing start up gas flow.
    Piezo lighter not sparking.
    Another possibility, strange as it mat sound, is the burner being blocked by mud-wasps; difficult to believe, easy to rectify.
    Coleman 10' X... | Answered on Nov 05, 2016
    There is a fuse located over the heating element in front of the fan. It sits over a small slot above the heating element (probably to cause it to stop working by design). Yes I'm a pessimist. It can be bypassed if it is an emergency by wiring across it. I'm trying to find the replacement fuse now (10amp jet 250v #00575) If you find it please send info to warfalcon23@Gmail.com. I hope we all get our heaters working, for $250 + dollars you'd expect it to last longer than 1 month.
    Coleman 10' X... | Answered on Oct 09, 2014
    Tough without pictures but this may be a model that has a spring base the lens is on. Try pushing down. If you post a picture I am sure I can help you out.
    Coleman 10' X... | Answered on Apr 20, 2014
    Replace the battery, Lowes sells the sealed lead battery's for $14.95. Check in the section they sell 'EXIT' signs the battery number you will be looking for is #30128 made by Utilitech.
    Step 1. Unlock the bulb careful not to pull too hard to prevent snapping off the ground wire for the bulb and unplug the 'black' and the 'red' wire from the battery terminals.
    Step 2. Locate the 2 screws on the side in the grey area use a P1 Phillips screwdriver a P2 will not fit.
    Step 3. Carefully pry the 2 half's apart dont pull too hard but just enough to allow the battery to slide out.
    Repeat the process in reverse to install the new battery.
    Coleman 10' X... | Answered on Jan 10, 2014
    Look up local RV dealers OR sail manufactures
    Coleman 10' X... | Answered on Jan 07, 2014
    Coleman 10' X 10' Sundome Tent 9160K101 Logo
    381 questions posted
    Top Coleman Sport & Outdoor - Others Experts
    Vernon Taylor
    john h
    Thomas Perkins
    Thomas Perkins
    Are you a Coleman Sport and Outdoor - Other Expert? Answer questions, earn points and help others
    View Most Popular
    • Coleman Sport & Outdoor - Others
    Most Popular Question
    need manual 2000 coleman taos pop up
    • Sport & Outdoor - Others
