HEWLETT-PACKARD LASERJET PRO P1606DN PRINTER Logo
Posted on Jan 04, 2011
Network cable is good and light on in back but printer says offline?
ravikumar
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Jun 13, 2014
ravikumar
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
1149
Points
11
First check printer IP & then ping it & assign to printer then it will work, if not swipe the formatter board then check.
3answers
My Brother printer is offline. How can I fix this?
If you are incapable to print to your installed Brother printer because it is looking as offline, then you can change some of the printer's settings so that you can resume printing documents. Windows gives a built-in feature for toggling between offline mode, which can resolve many of the "Printer Offline" notifications that you are receiving from your Brother printer. But, if this option does not solve your problems, you may need to make some real differences to your printer connection to replace normal printing functionality.
Steps that fix Brother Printer Offline Windows 10:
1. Click the "Start" button at the bottom-left corner of your computer screen, and then click "Devices and Printers."
2. Right-click your Brother printer icon, and then click "See What's Printing."
3. Click "Printer" at the top of the window, and then look for a blue checkmark to the left of "Use Printer Offline."
4. Full Solution of error is here- Brother Printer Offline Windows 10
If Brother Printer Offline Windows 10 is not resolved, this might mean there's waste within the printer's inside. Call the customer services our check this Blog for a full solution.
Printer went offline
is the network cable properly installed?
Btw, Iā€™m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Canon mp560 offline
Please also check whether USB cable is good. Did you compare it with other USB cable?
Cp1525nw appears offline
If the system is unable to detect the printer, it will put the printer in offline mode. In this condition you won't get any print outs..
1. chk usb cable
2. un plug the usb cable, un install the drivers, plug the usb cable & chk new hard ware found?.. if not there is usb port issue, chk system usb port/s are working or not.. if yes
3. Replace printer formatter assmbly...
This printer network unable printer, why cant use through network? instead of replacing the formatter assembly...
The printer show offline
Is this network printer or stand alone printer?
For both, check the power of printer.
For network printer, check print server is working, network cable from printer to print server is fine, check your computer connect to network.
For stand alone printer, check cable connect between your computer and printer.
If they are all good, restart your computer to let windows pick up your printer when it start up.
Hope this will help. Thanks for reading
1helpful
I can choose my network printer out of the network, but when I print to it, the document sit in the spool because the printer is offline. The printer it self says its "Ready to print". This is a...
Though you can see the printer in a list of network devices only means at one time that print was installed on your network and had not been removed. It says offline because there is a connection problem between your printer and your network. How is it connected to your network? Switch? Router? I know you checked the connections in back of the printer but did you check the connections on both ends? Also you can try to change the cables out , maybe the cables are bad. The printer may have to be reconfigured for your network.
Printer status remain offline how do i set it online again - all cables plugged in can see the printer in the network with status offline
make sure the lan cable is properly connected and you are able to acces the printer ip.
Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
2helpful
3answers
My HP officejet 4300 series stopped printing and shows that it is offline. How do I get it back online?
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
3helpful
3answers
HP Laserjet CP2025
If this is a new printer, chances are you may have left a piece of orange tape some where in the printer, otherwise you may have to remove the transfer belt, power the printer on and wait for it to say that it is missing, replace the belt and power on again, should fix it.
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Obehiaghe Adoghe
Obehiaghe Adoghe
ADMIN Eric
ADMIN Eric
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
