20 Most Recent HEWLETT-PACKARD Color LaserJet CP5225 Printer Questions & Answers
HP Printer, CP5225, Error message, Right door
This sounds to be a sensor issue. Try:Reconnect the connector (J708) of the 24V interlock switch and the connector(J121X) on the DC controller PCA.Also, try to check the sensor flag of the right door. If it is damaged,replace the right door sensor unit.The sensor worked for me.
12/21/2018 9:58:53 AM • HEWLETT-PACKARD... • Answered on Dec 21, 2018
Hp laserjet cp5225 cyan doesn't print
replace the cartridge or give it a good clean
4/9/2018 12:25:20 PM • HEWLETT-PACKARD... • Answered on Apr 09, 2018
Cp5225 cyan & megenta missing
need to replace those colour cartridges
4/9/2018 12:24:51 PM • HEWLETT-PACKARD... • Answered on Apr 09, 2018
50.7 fuser error?
Replace the Fuser
9/22/2017 10:26:48 PM • HEWLETT-PACKARD... • Answered on Sep 22, 2017
HP CP5225 printing too dark
In the settings menu there should be a economy mode which will lighten up the print.
9/22/2017 10:25:06 PM • HEWLETT-PACKARD... • Answered on Sep 22, 2017
How to replace dc controller board on hp cp5225n
Remove 5 screws from rear cover and remove it Open the right door to expose 2 screws holding right cover, release tab and remove Right Cover disconnect 22 cable connections and 6 flat cables from the DC Controller PCB Disconnect 3 intermediary wire connections and release the cables from the cable guides on the top and right sides remove 4 screws from the 4 corners of the DC Controller Remove PCB
4/6/2016 8:18:59 PM • HEWLETT-PACKARD... • Answered on Apr 06, 2016
Reset count kit fuser
On your Control Panel press the HOME button once then open : Admin Manage Supplies Reset Supplies New Fuser Kit Then use the Down ARROW to highlight YES then press OK
4/6/2016 7:58:41 PM • HEWLETT-PACKARD... • Answered on Apr 06, 2016
Cp5225dn error 59.0240
This error is indicative of a motor not working properly. Reseat all cartridges and drums and remove and reseat the belt. I've seen the belt cause all kinds of issues.
4/1/2016 5:01:38 PM • HEWLETT-PACKARD... • Answered on Apr 01, 2016
Reset menu english CP5225dn
You can change it in the Display Settings Menu. Print a menu map under administration/information to navigate your way
9/10/2015 5:08:27 PM • HEWLETT-PACKARD... • Answered on Sep 10, 2015
My printer will not print color, black and white only
sounds like greyscale might be turned on
1/5/2015 2:13:18 PM • HEWLETT-PACKARD... • Answered on Jan 05, 2015
Print mirror on cp5225
clean mirrors on the laser unit all four mirrord
1/5/2015 1:30:47 AM • HEWLETT-PACKARD... • Answered on Jan 05, 2015
Two sided prints
all you have to do is print the one side and then turn the paper over and then print on the back side.
12/29/2014 5:01:53 PM • HEWLETT-PACKARD... • Answered on Dec 29, 2014
2answers
Cp5225 printerseries the entire page with smudge
Is the toner bonded on the page? If not then the fuser is likely faulty. Otherwise you might have a bad cartridge. If you run the print quality test pages you should be able to tell if it is just one cartridge that is bad.
12/13/2014 9:58:05 AM • HEWLETT-PACKARD... • Answered on Dec 13, 2014
HP CP5225 ready for download
FIRMWARE - corrupted, you have to down load firmware.
12/13/2014 9:55:25 AM • HEWLETT-PACKARD... • Answered on Dec 13, 2014
How to remove casing
To make sure there is a clear understanding here's a complete diagram Overall Parts Diagram 18798043-wfiifre4chsxw5xgazxianfb-1-0.jpg To Remove the Outside Plastics on the HP Color LaserJet CP5220 Series Printer 1) Remove Right-front cover and control-panel assembly a) Open the front door and the right door. b) Remove two screws (callout 1). 18798043-wfiifre4chsxw5xgazxianfb-1-3.jpg c) Release 3 tabs (callout 1) on the right side of the assembly. 18798043-wfiifre4chsxw5xgazxianfb-1-8.jpg d) While holding the assembly up, pull the cable holder (callout1) disconnect one connector (callout 2). 18798043-wfiifre4chsxw5xgazxianfb-1-15.jpg 2) Remove Left cover a) Remove Tray 2 from the product. b) Open the front door. c) Remove three screws (callout 1). Starting from the left side tabs (callout 2),and then remove the cover from the product. 18798043-wfiifre4chsxw5xgazxianfb-1-24.jpg TIP: Opening the toner-collection door might make it easier to release the tabs on the left side of the cover. Reinstallation TIP: If the front door will not close after the left cover has been reinstalled, verify that the two tabs on the right side of the cover have been aligned correctly with the product chassis. 3) Remove Rear cover a) Remove six screws (callout 1), and then remove the cover from the product. 18798043-wfiifre4chsxw5xgazxianfb-1-35.jpg 4) Remove Toner collection unit access door a) Open the toner collection unit access door (callout 1), remove the toner collection unit, and then release the link arm (callout 2) on the left side of the door. 18798043-wfiifre4chsxw5xgazxianfb-1-48.jpg b) Partially close the door, and then disconnect the right-hand link arm (callout 1) from the door. CAUTION: Do not disconnect the right-hand link arm when the door is completely open. Doing so can disconnect the link arm spring. 18798043-wfiifre4chsxw5xgazxianfb-1-63.jpg c) Rotate the access door down 90 degrees, and then pull on the left side of the door to remove the access door. 18798043-wfiifre4chsxw5xgazxianfb-1-120.jpg 5) Remove Right-rear cover a) Remove the rear cover. See Rear cover on page 93. b) Open the right-door assembly. c) Remove two screws (callout 1), release one tab (callout 2), and then remove the cover. CAUTION: The grounding spring on the back of the cover falls off easily. Be careful not to lose it. 18798043-wfiifre4chsxw5xgazxianfb-1-143.jpg 6) Remove Top cover a) Remove four screws (callout 1). 18798043-wfiifre4chsxw5xgazxianfb-1-99.jpg b) Open the toner-collection door. c) Release two tabs (callout 1), and then remove the cover. 18798043-wfiifre4chsxw5xgazxianfb-1-168.jpg 7) To Reassemble Follow Instructions in Reverse
12/1/2014 2:13:00 PM • HEWLETT-PACKARD... • Answered on Dec 01, 2014
COLOR LASERJET PRINTER CP5225
What is the problem you faces with this printer? Provide more details, please. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
11/18/2014 10:51:14 AM • HEWLETT-PACKARD... • Answered on Nov 18, 2014
HP 5225 wrong fuser inatlled
Did you get a fuser for a 5525 instead? They fit but are different.
10/23/2014 5:24:04 AM • HEWLETT-PACKARD... • Answered on Oct 23, 2014
How to reset the fuser counter on a hp cp5225
PRESS HOME BUTTON & OPEN FOLLOWING MENUS. ADMINISTRATION ~ MANAGE SUPPLIES ~ RESET SUPPLIES ~ NEW FUSER KIT, THEN USE DOWEN ARROW BUTTON TO HIGHLIGHT " YES " ITEM THEN PRESS OK.
10/11/2014 12:38:52 PM • HEWLETT-PACKARD... • Answered on Oct 11, 2014
HEWLETT-PACKARD Color LaserJet CP5225 Printer Logo
35 questions posted
Top HEWLETT-PACKARD Office Equipment & Supplies Experts
Daniel Blask
Daniel Blask
Obehiaghe Adoghe
Obehiaghe Adoghe
Are you a HEWLETT-PACKARD Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
LaserJet HEWLETT-PACKARD
  • LaserJet HEWLETT-PACKARD
Most Popular Question
cp5225n wrong fuser installed error
  • Office Equipment & Supplies
