Hobart SR24-H Built-in Dishwasher Logo
Posted on Dec 22, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where does the detergent go in for the H series of SR-24?
Barrett Palumbo
Level 2:
  • Expert 1,772 Answers
  • Posted on Dec 22, 2010
Barrett Palumbo
Expert
Level 2:
Answers
1772
Questions
0
Helped
502264
Points
289
Sorry to read about your problem, I hope this helps you out.
you do not put soap inside the unit, you hook up 5 gallon soap buckets, their a plastic feed hoses..
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
1helpful
My ONKYO has a good picture but there is know sound .
Must be DSP problem no matter what model it is. TX-SR/NR OR even RZ Series.
(1)If old model TX-SR/NR, you should replace the BGA DSP Q3001 "D830K013A/BZKB" TO "D830K013DZKB"IF DZKB get damaged, replace it with same DSP Chip-DZKB.
(2)For Tx-SR series, the DSP Q201 TMS320D788E001B SHOULD BE replaced with same model.
(3)For new model, RZ series the DSP Q3404 CS49844 should be replaced with same model.
(4)Crystal marked X201/3001/3404 should be replacd.
I have a Samsung Dishwasher DMT800RHS, dishes have brown film, tried Lemon Magic, fixed 9e code, still dirty dishes. Used liquid detergent, still dirty dishes. Sometimes white film.
Sounds like its not draining properly between cycles. Its time for an appliance engineer I'm guessing. Can you access the drain pump hose area to see if its clogged.
How to instaal viking detergent dispenser
remove kick plate, bottom access panel, door panel and door latch (careful with the wiring) and than remove the 6 screws and 2 brackets holding soap dish.
1helpful
After a wash, my Quiet Series 100 Maytag washer has fine grit all over the inside of dishes. Is there a filter somewhere I should be cleaning?
Try changing the brand and type of detergent that you are using. Some seem to work better under hard water conditions. Hope this helps.
Detergent packs will not dissolve
check the water temperature, run hot water at the adjacent sink before pushing start on the dishwaher, or switch to powder, is your detergent door opening ? do not block the detergent door with long objects like spatulas etc.
1helpful
I am looking for an owners manual for my Epic Series 6500 SR.
Owners manual in pdf-format Electrolux Epic Series 6500 SR:
http://homeappliance.manualsonline.com/ex/thread/view/idThread/1424472
Clicking "Epic6500.pdf" will pop up a registration shortly,
but the manual appears directly after that.
The glasses look milkey
try using rinse aid, or try different detergent
Detergent dispenser
Here is a link. Sears.com as almost any part for anything including diagrams. The pricing on the part seems WAY out of range. Usually dispensers cost around $60.00 At least you can find the p/n and google around for it on some other sites. I can't imagine it's that much.
http://www.searspartsdirect.com/partsdirect/showPart.pd?partNumber=PD150001&productGroupId=0022&supplierId=425&brandId=x&documentId=10057058&keySuffixId=NA&modelNumber=x&keyId=000018&pageId=00002&productTypeId=x&searchModelNumber=VUD141&subCompDesc=Door&brandDesc=VIKING%20RANGE%20CORP.&modelDesc=UNDERCOUNTER-DISHWASHER&backToLink=Return%20to%20part%20list
Top Hobart Dishwashers Experts
vince
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
