LG 42LE5400 42 in. LCD TV Logo
Posted on Dec 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is it possible to mount the 5400 led with a typical wall mount? I do not see any holes in the back for bolts/screws/brackets or anything!
laseray
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Dec 09, 2013
laseray
Contributor
Level 1:
New Friend:
Answers
14
Questions
Helped
4931
Points
31
The LG 42LE5400 should mount using a standard 200mm x200mm VESA mounting bracket (they even spec this). When you buy a TV mount, this should be included. There will be holes on the back of the TV to accept the brackets for mounting but you will need to be very careful to use the correct length of screws (they should NOT be too long - and remember they are metric, not inch threaded screws!)
Good Luck,
Ray
Anonymous
Level 3:
Master:
  • Master 362 Answers
  • Posted on Dec 21, 2010
Anonymous
Master
Level 3:
Master:
Answers
362
Questions
0
Helped
66786
Points
1092
Look for larger flat ones they are plugs to hide the mounting slots
2answers
I have a Samsung UN32M530D smart TV that I want to mount on the wall. The 4 holes at the back of the TV are smooth and do not have threads for screws. How do I attach the TV to the wall mount?
You can check https://www.primecables.com/c-18871-mounts-sit-stands for mounting sets or standing desk to your Smart TV. I got a standing desk there and going to mount it soon. It's much more comfortable then to use a simple wall mount.
CAN I GET SCREW HOLE SIZE OF BACK OF TV FOR WALL MOUNT
The 3 most common sizes for the bolts to mount the wall mount to the TV is either M8x20mm or M6x20mm or M4x20 depends on the size of the screen. This site has a chart that will show you what to look for, for your TV M6x20mm TV to Wall Mount Bracket Phillips Bolts Screws Stainless VESA 200
2helpful
Screw size for wall mount 32 inch model TDE3253
Bolt size is M6 bolt pattern and thread pitch. A 15 to 25 mm long bolt is recommended depending on the thickness of the wall bracket.
I got got this from GPX. If you email them you can get the full TV guide.
Wall mount Sanyo LCD-32xr8DA
look at the middle of the tv the 4 screw mount thats wre the tv wall mount gos. good luck
I need help finding mounting screws and bolts for my 47" 1080P 120HZ LCD w/2YR. The table that I bought for the tv dindn't bring them.
If you want to put the LCD on a stand you"ll need the original that screws on the bottom. best way to mount LCD is to the wall or on a metal stand. There are holes on the back of the LCD to mount the bracket most brackets have a lot of holes just move the bracket up or down until two line up. The screws are almost all metric coarse thread and usually are included with the bracket kit. I got my kit at Wal Mart
5helpful
2answers
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
2helpful
Is plasterboard (with battens behind) strong enough to install a Roca Kalahari wall-hung sink against or do I have to reinforce it using tiles or a bracket?
Ok. Big answer. Where the sink is going to be mounted there needs to be inside the wall structural support mounted between the wall studs. This could be a 2X6 or 2X8 nailed from one wall stud to the next at the height the sink will be mounted. Then once you have repaired the sheet rock you can measure the distance the mounting holes in the back of your sink are and drill these holes smaller than the mounting bolts/screws for your sink. Screw the screw portion into the wall using the nuts on the bolt side and a wrench. Remove the nuts and the slide sink into place where the bolts/screws fit into the mounting holes in the sink back. Install washers and nuts and tighten to wall.
Instalation Instructions for Frigidaire Over the Range Microwave 850 Watt Model #FMT118EPB
HI,
Frigidaire makes several over-the-range microwave models that are all installed in the same manner. To install correctly, you must have at least 45 1/2 inches from the bottom of the top cabinet to the cooking surface of the stove to provide enough clearance for the microwave. The top cabinet must also be at least 30 inches wide and 12 inches deep. Find someone to help you, then follow the steps below to install your Frigidaire microwave.
Things You'll Need:
  • Stud finder or hammer
  • Screwdriver
  • Drill
Instructions
Pull your range away from the wall so you can work comfortably. If this is not possible, cover it with a drop cloth. Find and mark the locations of the studs in the wall behind the range. They will be either 16 or 24 inches apart.
Follow the instructions on the wall template to mark the location of the mounting bracket and the four anchor holes on the wall and the bottom of the cabinet. Drill the anchor holes. Follow the instructions on the top cabinet template to mark and drill the two holes in the bottom of the cabinet.
Attach the mounting bracket to the wall studs using the six wood screws included with your microwave. Screw the toggle nuts onto the toggle bolts and push one through each of the four drilled holes. Screw each toggle bolt until the nut is snug against the inside of the wall.
Pick up the oven with your helper. Plug the oven into the outlet and slide the oven onto the mounting bracket arms. Push the oven back against the wall. Tighten the two screws on the microwave faceplate to fasten the microwave to the mounting bracket arms.
Attach the louver to the top of the microwave with the three provided screws. Insert the two top cabinet screws and washers from the top cabinet into the microwave and fasten tightly.
Take care.
1helpful
How do you remove the base inner bracket parts so that you can mount the TV on to a wall?
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
