20 Most Recent
LG 42LE5400 42 in. LCD TV Questions & Answers
I've had the lg 42le5400
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
La pantalla no enciende
Hola, tengo el mismo modelo y la misma falla.
Encontraste alguna respuesta o ya pudiste resolverlo?
Le5400 sound options to escape persistent headset mode
Hi and Greetings
This is a mainboard failure
Is your set keep saying that the headsets ar on and no sound from the tv whatsoever ???
Then the failure is located at the headset plug
If you have any experience with fixing electrical stuff then you should be fine by replacing it
hope I was helpfull
