20 Most Recent
Panasonic TX-32LXD1 32 in. LCD Television Questions & Answers
Will not tune into itv3
Two things make certain the aerial is good and the cable from it is not the old type brown cable (replace it with satellite cable). Digital sets need good signals and it will clear up the breaking up of the picture when cars go past etc.
If you do have a good aerial & cable. Try resetting it to the factory default. That should clear the memory settings of the tuner. As sometimes it remembers you had channels and therefore ignores them. Then rescan!
2/11/2010 12:21:51 PM •
Panasonic...
Answered
on Feb 11, 2010
I need a remote control code to match my BT Vision
Hi, Andrew! Does your remote control have a "code search" mode? Panasonic products are mandatory for all of universal remotes. but, new flat panels are, usually in a special section of your code manual, if you still have it. If not, try to start aut code search procedure and be patient: it might take 10-15 minutes till your set will start to respone. make sure, enter the code to memory, as soon as you see the set took the code. Otherwise? You must start all over.
1/23/2010 12:16:49 AM •
Panasonic...
Answered
on Jan 23, 2010
How do you remove the base inner bracket parts
What make and model?
Most wall-mountable TVs will have threaded holes in the back for wall-mounting. Most of which you can bolt a bracket to then unscrew a few of the set-screws for the stand and slide the TV off of the stand.
Most TVs have 4 set screws for the stand located near the bottom middle of the TV where the stand inserts into the TV. The screws may be recessed fairly far into the back of the set and may require a long thin screwdriver.
1/1/2010 6:42:15 PM •
Panasonic...
Answered
on Jan 01, 2010
Hi
Hi There,
Try restore the tv to factory state. It could be a burn in from a tv station you always watch eg. Some lcd will have a non burn in function, What that means simply is if you watch mtv all the time it will leave the mtv sign in the corner as its burned into the tv. Depends on how old the tv is restore and see what happens from there, other than that get an engineer or replace it if its still under warrenty....Hope this helps
11/17/2009 12:03:07 PM •
Panasonic...
Answered
on Nov 17, 2009
I have no bbc1 or other main channels after
Try looking at the EPG (Electronic Programme Guide) and selecting one of the missing channels if it is showing on screen. If you can receive the broadcast then it means that your channel list has been rearranged into a different order and you will have to manually edit the list to get the programmes in the order that you need. If the channels are not there then try retuning again.
10/14/2009 2:47:45 PM •
Panasonic...
Answered
on Oct 14, 2009
