Step 1: Download and Run/Save the Error Repair Tool
Step 2: Next, click the SCAN button.
Step 3: Click the REPAIR button to fix your errors.
for more help visit CBR Tech Solutions
SOURCE: DIR-615 D-Link Router Problems...!
Try to reset the router first by pressing the reset button at the back of the router for 20 seconds then power cycle it by unplugging the power for 30 seconds then plug it back in. Here's how to set it up
1. You don't need to use the setup CD that came with it.
2. Make sure you have the proper physical connection
3. From your modem, connect the ethernet to the Internet/WAN port of the Dlink, then your computer to port # 1.
4. Do a power cycle. Unplug power to router and modem. Wait for 30 seconds. Power on the modem first, wait for all the lights to steady then power on the router. You should be all set
SOURCE: how to install the cisco
there are two ways of installing a linksys E-series router
>>first is the easy setup disk/ if it will not work, try to dissable the firewall of your computer
>>if still doest work, you can access the setup page of the router with the DG, 192.168.1.1
>>for cable connection always do a mac address clone
>>for DSL, change the lan IP,
>>call linksys tech support, iwill be glad to solve your problem
