20 Most Recent D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Questions & Answers
Hi, p[lease follow these instruction religously::
  1. Insert a blank recordable DVD into your DVD burner.
  2. Use Photo Story 3 for Windows to create the story you want. On the Save your story page, you will have options "Save your story for playback on your computer", "Send the story in an e-mail message" and etc. If you scroll down to the last option listed, it will say "Save your story to a DVD for playback on your home DVD player". That is the option you need to choose to burn the slideshow on DVD. Click Next to temporarily save the photo story.
  3. On the Completing Photo Story for Windows page, click Continue and save your story to a DVD for playback on your home DVD player.
  4. In the Create a DVD dialog box, put in the DVD Title and Video Title as well as choose the DVD burner you desired if you have more than one DVD burner installed. Click Create DVD to start the buring process.
Please note: Sonic DVD for Photo Story 3 can only burn DVDs. It does not burn CDs. Also, only one story can be burned on each DVD.
LAST UPDATED: Jun 25, 2007
D-Link AirPlus... | Answered on Aug 17, 2019
Verizon Home DSL service uses a special filter that prevents ALL incomming connection including web, email and VPN hosting from a home connection. Business internet does not limit this, and I don't believe FIOS blocks it. If you have verizon home, there's nothing you can do. If you're just trying to connect to a home machine, you can try something like gotomypc, or a free alternative like teamviewer.com or logmein.com.
If you don't have verizon home dsl, comment back with what service you do have, and we can try some other things.
Steven
D-Link AirPlus... | Answered on Jul 17, 2019
Try going to D-Link website for firmware upgrade to this model, Also make sure u download the the firmware for the version of windows you are using. In order to upgrade, the router must be hard wired that is connected directly to your modem as unit will not upgrade using wireless connection.
Hope this helps you!!
D-Link AirPlus... | Answered on Jan 04, 2019
try admin/di-624. where "di" may be capped.
D-Link AirPlus... | Answered on Aug 26, 2018
you can reset your router, at the back you easily find very little button which indicates that is the reset button. press reset then you will be able to fix your new user name & password.
Thanks
D-Link AirPlus... | Answered on Apr 26, 2018
this is all i could find out..
The way to fix this is to unplug both your modem and your router (you may have one piece of equipment that acts as both) and wait a full 60 seconds. Then plug them both in again and wait for all the lights to stop flashing. At that point, try to reconnect to the Internet again.22 Mar 2017
What To Do If Your Wi-Fi Suddenly Stops Working ' Tech for Luddites
https://techforluddites.com/fix-wi-fi-problems/..
or go to this link.
WIFI just stopped working Google Search
D-Link AirPlus... | Answered on Oct 30, 2017
This is a common problem with VPN and by no means confined to Verizon. You will need to check with whoever you are VPN connecting to as it is most likely they that are experiencing a problem and dropping your connection. Contact the host Network Admin or Support team to assist you. I have had this happen many times, especially when travelling and it has never been an issue with my laptop and has always been the host.
D-Link AirPlus... | Answered on Apr 19, 2017
Make sure router transmit is set ON and at High power. Reboot to see if it appears. If not try a complete factory reset.
D-Link AirPlus... | Answered on Jan 31, 2017
Login to the router and go to DHCP clients and see their IP and MAC addresses.
D-Link AirPlus... | Answered on Jan 07, 2017
Go to the D-link website to see if an update is available. Login to your router to see your current firmware version an hardware version. If update is available, download to your computer and upload to your router.
Well, if you run a LAN cable from your existing router to the DI-624 in a remote location you could use it as an AP, but this router does not support repeater of bridge modes.
D-Link AirPlus... | Answered on Jan 06, 2017
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Usually you can login on your browser to you router and go to the management section to check for firmware updates and select that button and it will download and install the firmware. On some models, you have to go to the D-link web site and look for firmware updates for your router. Always check what you current firmware you have installed and check the version of your router modem hardware (A, B, C etc). Then you can manually download the firmware (usually in a ZIP file), open the zip file, and then using your browser connected to the router look for Update Firmware. You will have to go to where (folder) you saved the downloaded update and select that file. It is recommended that you update using a LAN connection and not a wireless connection.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
Have you done a factory reset or just a reboot?
Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Login to your device and go to the wireless section. There you can set up a wireless password/key. Make certain you keep track of this password. Another thing you can do is turn OFF the Broadcast SSID that will make you wireless network invisible to devices.
Not sure if there are any more firmware upgrades for this model, but you can check on the D-Link website. Connect to your router using the browser interface and see what firmware is already installed. Then under the support section on the D-Link website look for firmware updates form your model. If there is, then Download to a known location on you computer (usually comes as a ZIP file). Unzip the file and using your browser connected to the router, upload the update.
your firewall may be blocking it.!!!!!
D-Link AirPlus... | Answered on Dec 20, 2016
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
523 questions posted
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • D-Link Computers & Internet
Most Popular Question
find new username password re config
  • Computers & Internet
