Kia spectra 2002. open the engine cap and saw thick layer of slugish dark engine oil. B4 start engine check the engine oil seem to at very low side. Worry engine condem?
what should i do or to confirm the leak is true. How to know how bad is the leak?what should i do or to confirm the leak is true. How to know how bad is the leak?
the check engine light comes on to tell you there is a problem with something the computer controls or receives info from. Have the computer scanned for codes. Once you have those codes post them here and I'll be happy to help you further.
follow the lines from the compressor each line should have a fitting with a screw on cap the hose you bought with the R134 should only fit the low pressure side just make sure you got the hose with a gauge.
A sign that you need new rings since excessive loss of oil and white smoke means oil is going to the combution chamber of the engine and bad rings are letting that happen. take it to a technician to make sure you get it right. Thank you for visiting Fixya.
Check the socket to see if voltage is spiking over 13.5 volts with a voltmeter while revving engine . Charging could be bad.Look for bare wires around the assembly as well.
take the car to auto zone and get all the fault codes recorded
that is the first step in saving money as it is free
next find an accredited service center that has experience on your make of car and show them the fault codes to get fixed and only what needs fixing
pay for nothing else
