SOURCE: Where can i download acer arcade or acer arcade deluxe for my notebook
what is it?a support driver?you can download it in acer website by using correct searce engine and by inputing the correct model.
SOURCE: Acer Aspire 5920 - Acer Arcade Deluxe Problem
in bios, locate windows vista and set it up to start automaticly , (default operating system)
SOURCE: Start up stuck on Acer Arcade Deluxe screen
if you can boot into safe mode by pressing f8 at startup, check the startup folder for acer arcade and remove it if present.From your start button go to (start-programs-startup).
another option is to check the run key in the registry: one caveat though - please don't mess with things in the registry you don't understand. Deleting or changing unknown registry keys can result in a non-booting pc.
please stick strictly to my instructions and you will be fine. We're going to look and see if windows is calling the acer arcade to run at boot time:
click your start button and type 'regedit' (no quotes in the start search field. A window titled 'registry editor' will appear. Now, to expand a field in the registry, we left-click on the triangle on the left side of the field.
so, click the triangle beside HKEY_LOCAL_MACHINE
go down to 'software' and click the triangle beside it. go down to Microsoft and click the triangle, go to windows and click the triangle, go to current version and click the triangle, go to run and click on the run folder, not the triangle beside it.
Now look in the list of items in the run folder. these are all items that run when your pc boots. If you see an item with 'acer arcade' or just 'arcade' in the name, then delete it. DO NOT DELETE ANY OTHER REGISTRY KEYS....PLEASE!
if you found acer arcade and removed it then reboot and all should be better. if not, boot to safe mode again, click start button and type in 'msconfig' - no quotes. go to the startup tab, and again only uncheck anything with acer arcade in the name.
Hope this helps!!
SOURCE: The Acer Arcade Deluxe Webcam is not working, but
You can do the following: Start your PC as an administrator > click Start or the Windows ball > Control Panel > Performance and Maintenance > System > Hardware > Device Manager > Scroll down to the device driver you wish to roll back > right-click on it and choose Properties > Click the Driver tab and then click Roll Back Driver. Note: Win7 ball > Control Panel > Device Manager. By rolling back the driver, your Arcade Deluxe Webcam should work like it used to.
SOURCE: I uninstalled acer arcade deluxe, how do I get it
Contact Acer and they will provide you the link.
Otherwise:
Acer Arcade Deluxe v2.0.5105 Full installation
http://rapidshare.com/files/11818868...5105.part1.rar
http://rapidshare.com/files/11818941...5105.part2.rar
mirror:
http://www.megaupload.com/?d=0XTBHTLY
http://www.megaupload.com/?d=2EW2EIQ1
mirror:
http://www.filefactory.com/file/1d79cc/
http://www.filefactory.com/file/acc1a8/
Acer Arcade Deluxe 2.0.5312 Full installation
http://www.megaupload.com/?d=COYIPTIW
mirror:
http://rapidshare.com/files/133165549/AAD205312Full.rar
mirror:
http://www.filefactory.com/file/939703
Acer Arcade Deluxe 2.0.5319 Update only
http://www.megaupload.com/?d=D35AA537
mirror:
http://rapidshare.com/files/13315947...5319Update.rar
mirror:
http://www.filefactory.com/file/68cd2
b
