20 Most Recent Acer Aspire 6920 Notebook PC Questions & Answers
Check model numbers, I had this problem with apple, to of the same laptops two differnt batteries
Acer Aspire 6920... | Answered on Apr 04, 2017
When you boot up start pressing F8 and you should get a Windows startup page with more options. If you do select Safe Mode
When windows has loaded, goto MSConfig and select Diagnostic Startup. Ok and reboot
See if windows boots normally.
Acer Aspire 6920... | Answered on Feb 15, 2017
hi there i have just had the same problem on my 6935g and i found the way to solve it is to take the bateery off for 30 secs and when you start it back on the problem should be solved it is not the answer to the problem as it may recure but it gets your cinedash working again the site i got this solution said that this is the solution that acer give out
Acer Aspire 6920... | Answered on Jan 07, 2017
i have the acer 6920g notebook and had windows 7 installed and cant get my virtual surround sound working can you give me any clues. thanks
Acer Aspire 6920... | Answered on Sep 05, 2016
go into control pannel and acer hd set it there and also in sound, a wee bit of trial and error but its there. mine was the same, it cost me ouch on the phone! good luck mine works ok
Acer Aspire 6920... | Answered on Apr 18, 2015
check and make sure your vga drivers are upto date.
or get a lens cleaner and clean the lens.
make sure your ram is ok.
Acer Aspire 6920... | Answered on Apr 05, 2015
hey there, not sure if you can do this or not but it will clear your cmos. Boot up MS-DOS and enter the DEBUG program. Type the following commands: The following commands will clear CMOS:
-o 70 2e <CR>
-o 71 ff <CR>
-o 70 2f <CR>
-o 71 ff <CR>
It may be necessary to reboot the computer a couple of times to correct any CMOS and errors.
Acer Aspire 6920... | Answered on Feb 25, 2015
You can use this tool to help installing the drivers directly on you pc
DRIVER ROBOT
Here's how to do it.
* install the software and run the program after installation.
* if ask for Key registration, just enter this code : JCCQ-MAKC-KACK-6TSE-BN35
* Tick "Scan" to begin (it will detect all drivers that needs to be update
* click start to begin downloading (you can choose which driver you want to download)
* click "Install" and it will automatically install on your pc.
This are the supported drivers :
* Sound card drivers
* Printer drivers
* Video card drivers
* Motherboard drivers
* Webcam drivers
* Wireless drivers
* Bluetooth drivers
* FireWire drivers
* Ethernet drivers
* Windows XP drivers
* Windows Vista drivers
* USB drivers
* Chipset drivers
* AC97 drivers
* DVD drivers
* Router drivers
Acer Aspire 6920... | Answered on Nov 01, 2014
Hi
Thanks for using FixYa. You’ll need to reset the Laptop as per the procedure given as under---
Remove all the connections to and from the Laptop. Now remove the battery and press and hold the power on button for 2 minutes. Release the power on button. Slip in the battery pack. Plug in the power to the laptop and to the wall. Please do not plug in any other devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Acer Aspire 6920... | Answered on Aug 29, 2014
Which Password? Bios Password? Hard Drive Password? Windows Welcome Screen User Logon Password?
Which Operating System?
Acer Aspire 6920... | Answered on Jul 18, 2014
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
Acer Aspire 6920... | Answered on Apr 14, 2014
There may be a hardware change or driver issue because in safe mode, it doesn't load VGA drivers or other hardware. Use safe mode with network support and use the help file to guide you.
Acer Aspire 6920... | Answered on Feb 13, 2014
Please try these. After on your pwoer botton wait 2 minites and the press FN+F6.
Let me know what happening.
Thanks.
Acer Aspire 6920... | Answered on Jan 05, 2014
Drivers are available from acer.com
Acer Aspire 6920... | Answered on Dec 12, 2013
Sounds like the MBR ( boot files) are corrupted. Try formatting the hdd before you instal again. I'm sure you have a restore sector on the hdd in which case, if you have done anything to that then you'll need to have the restore disc set which usually comprises of the restore disc and the drivers disc. Either way....just make sure you format c and not d which is usually the resore partition. Good luck
Acer Aspire 6920... | Answered on Nov 26, 2013
Acer Aspire 6920 Notebook PC Logo
449 questions posted
Ekse
Alun Cox
View Most Popular
Aspire Acer
  • Aspire Acer
Most Popular Question
download virtual surround sound drivers
  • Computers & Internet
