SOURCE: Dyson DC07 burning smell.
sounds like it is on the way out this may be because 1, you need to clean the filter cos when its dirty it stop air from going around the motor witch makes it get hot and overheat 2, also if you allow the bin to get to full this will also stop the motor from geting air to it so a good clean on your filter and bin will allow air to the motor then no overheating should accur
SOURCE: problem fitting new motor into dyson dc07 casing
Hi.
There is try this site http://dysonmanuals.inc.io/
SOURCE: dyson dc07 motor sparks
Hi.
I think you are looking at replacing the motor with a new one.
http://dysonmanuals.llc.nu/
Chris..
SOURCE: dyson DC07
First, check your outlet for power...plug something else in. Then, inspect the cord and check the power switch. You can use a multimeter to test across the power plug of the vacuum in the ohms position. Turn the switch off and on. If it does not change readings...the switch or cord is bad. If it does, it might be the motor.
SOURCE: Dyson Dc07
I had the same issue and solved it easily.My experience is the same as the March 6th response/ When you push your foot onto the base and then recline the handle, use your toe to gently push the very front of the base down closer to the carpet. This creates a much stronger seal and suction and picks up every bit of dirt easily. If i do not do this extra step the suction is much much less. I tried an experiment with sand that I poured onto my carpet. Initially, I went over the sand 4 times and the dyson 07 would only pick up 50 percent of the sand. I then poured more sand onto the carpet, and this time pushed the front lip down so it was contacting the carpet. This time only two passes were needed to completely **** up all the sand. Not sure why this is not in the manual but it really works. Good Luck!
