Well obviosly he heater has electrical fault seek electrician, the lights not coming on means electrical fault on heater if new get replacement under warranty if not get electrician to fix for you do not attempt to fix electrical problem if your not a electrician or a restricted electrician, maybe an appliance fixing shop may be your best place to try but it sounds deffinatly electrical
Hi, Its very possible that you have the wrong power to your fryer. I noticed that you said that you tried to plug it in. If it does not seem to fit or if you had to bend anything on the plug to make it fit you need to have an electrician check to make sure you have the correct power to the fryer. The wall outlet will have the power information printed on it. The manual will give you the power requirements. It the plug fits ok, check your breaker for that outlet. Good Luck. If this solution does not rate an (Almost There) Please do not rate.
Thank You,
kstfas
