20 Most Recent
Comfort Zone CZ7007 Oil Filled Electric Radiator Heater Questions & Answers
How much does it cost, per hour, to run a Comfort Zone electric heater (model no. CZ7007)?
Here is the easy way to find out. For a few dollars, you can buy a wattmeter of the type you plug in the wall and then plug your appliance into the meter. These meters will tell you the current power consumption, the accumulated power consumption, and can be programmed to automatically show you the cost-per-hour (or day, etc) to run your appliance. You can use them on any appliance. They have a simple digital read-out. Shop around to find one that does everything you want to know. Some have wattage limits, so be sure it will be enough for your heater. Heaters use a lot of power (watts).
Had both switches to ON, with the dial turned to 7
well obviosly he heater has electrical fault seek electrician, the lights not coming on means electrical fault on heater if new get replacement under warranty if not get electrician to fix for you do not attempt to fix electrical problem if your not a electrician or a restricted electrician, maybe an appliance fixing shop may be your best place to try but it sounds deffinatly electrical
Won't heat my studio - even on "HIGH"
Does it get hot? If so, that is all you will get! It is not made to heat a room of 20 X 15 X 8 feet high. That is 2400 cubic feet of air space that may or may not be insulated. You need a quartz heater or two that are designed with fans to heat larger areas (see the specifications on them). The oil filled radiator is to put next to your rocking chair or under your desk near your feet!
I hope all is well:
Good day, Doctor.
First, have you tested the wall receptacle that the heater is plugged into? Have you plugged a lamp or other electric appliance into it, to see if it's working? If nothing else works in that receptacle check for a tripped circuit breaker in the panel box of your home.I f there is one tripped, make sure nothing is plugged into the offending receptacle and reset the breaker, by turning it on. If one is tripped, now you need to figure out what tripped it. Was it the heater? Probably so. In any event, plug the heater back into the receptacle and turn the heater on. Did it trip the circuit breaker again? If so, there is an electrical short in the heater. Since you have only had it for 3 months, I would assume it's still under warranty. If so, follow the instructions in the Owners Manual about returning it to the manufacturer for repair or replacement.
Hope this helped to solve your problem.
How many amps does it draw?
There has to be a tag on the unit that can answer your question. On this tag you want to look for the run load amps. (RLA) Thats your answer.
Is there a recall on
Have you tried resetting the unit?
just push and hold the two buttons on the right for 3 seconds and it will reset.
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
How do you turn on
On the comfort zone CZ7007, the #1 rocker switch is for 600 watts, the #2 rocker switch is for 900 watts. If you flip 1 and 2 both to on you will get 1500 watts. Which is 600 and 900 added together. There is no down position, but only on and off.
