British thermal unit: a unit of heat equal to the amount of heat required to raise one pound of water one degree Fahrenheit at one atmosphere pressure; equivalent to 251.997 calories. The amount of heat needed to raise 1 pound of water 1 degree F (equal to 252 calories).
(British thermal unit) Describes the heat value of fuel for appliances - the higher the BTU, the more heat available for cooking.
A Btu is equivalent to 252 calories and serves as the base unit for measuring the heat content of a fuel source.
-The Ugly Pool Guy
www.wefixuglypools.com
A BTU, short for British Thermal Unit, is a basic measure of thermal (heat) energy. One BTU is the amount of energy needed to heat one pound of water one degree Fahrenheit, measured at its heaviest point. In other words, if you placed 16 ounces of water at 59°F into a stovetop pan and turned on the gas burner, it would take one BTU to raise the temperature of the water to 60°F. As more BTUs continue to flow from the gas flame, the water will eventually reach the boiling point of 212°F.
