20 Most Recent Goodman CKL36AR36 Air Conditioner Questions & Answers
Factory parts warranty is five years all parts one year labor. Capacitor and/or fan motor has gone out and will need replaced. The breaker will throw itself off if the condition gets bad enough. Suggest not using until repaired, turn off breaker.
Goodman... | Answered on Oct 30, 2018
call in the technicians
compressor shutting down or power to the fan being interrupted causing the compressor to shut down
Goodman... | Answered on Jan 23, 2018
point of piston goes toward coil
Goodman... | Answered on Aug 18, 2015
there is a 3 amp automotive type fuse on circuit board to protect transformer in air handler
Goodman... | Answered on Aug 14, 2015
fan relay stuck in.
most dont have a high pressure safety. the compresor trips on internal drawing to many amps.
ihe 5 minute delay is to prevent damage to your compressor. some safety is shutting it down.
stopped up drain or rusted out pan. should have auxiallry pan under a/c air-handler.
Goodman... | Answered on Aug 12, 2015
drain pan stopped up or rusted through. if you are talking freon leak has to be repired by a pro.
Goodman... | Answered on Aug 11, 2015
either you have refrigerant leak or compressor bad.
on the side of compressor is a plastic snap on cover. behind cover are 3 terminals labeled r for run c for common and s for start. make sure a wire has not burned off. remember power has to be off and capacitors store a charge that can hurt you.
Goodman... | Answered on Aug 09, 2015
possible but i would check line set first.
Goodman... | Answered on Jul 05, 2015
The compressor has three terminals, Common, Start and Run.... The terminals read left to right, top to bottom just like pages in a book. So if theres one on top, its Common then Start will be the first one in the next row. If theres two on top, it'll be Common on the left and Start on the right then Run on the bottom.
The run capacitor wires in between Start and Run and line voltage is applied to Common and Run.
Goodman... | Answered on Apr 14, 2015
Wiring diagram is on the inside of the service panel on the condensing unit.
Goodman... | Answered on Apr 11, 2015
Freon can only be added to a refrigeration system by an EPA qualified technician
Goodman... | Answered on Mar 26, 2015
The wiring diagram is on the inside of the door on the blower/air handler unit.
Goodman... | Answered on Jan 08, 2015
Goodman CKL36AR36 Air Conditioner Logo
217 questions posted
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Goodman Heating & Cooling
Most Popular Question
outside ac unit not blowing goodman dk
  • Heating & Cooling
