Kitchen Ranges Logo
Posted on Dec 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Microwave went dead while in use all power outlet is working so it's not circuit breaker cant afford new one or repairmen
  • 1 more comment
  • DILLIGAF
    DILLIGAF Dec 05, 2010
    Does your microwave have a digital display for the time, etc? Is the display on and are there any signs of power? If there is no power at all it may just be a fuse, but I will need to know the brand and model number of the microwave to assist you further. BElectric
  • cgmiller1956 Dec 05, 2010
    Kenmore model# 665.60654 no display no lights nothing
  • DILLIGAF
    Thanks, I will get back to you very shortly.
DILLIGAF
Level 3:
President:
  • Master 1,140 Answers
  • Posted on Dec 05, 2010
DILLIGAF
Master
Level 3:
President:
Answers
1140
Questions
Helped
681326
Points
4145
Firstly, microwave should really be serviced by qualified professionals as they contain high voltage components that can still give you a shock even when they are disconnected from the power. Please follow all the safety instructions (underlined) included here.
If there is no power at all it could be the fuse. Please disconnect the power from the outlet or make sure the breaker is off before doing this. There should be a small panel about 6 inches wide/high on the side or back of the microwave which can be removed by undoing a couple of screws. Under this panel you should find the fuse assembly which will look something like this:
The fuse is the white cylinder with the silver ends in the top right of the picture. If you remove a panel and don't see the fuse, replace the panel and look for another panel. Occasionally the removable panel is inside the cooking compartment.
When you have located the fuse, pry it from the fuse holder carefully using an insulated screwdriver if possible. Test the fuse with an ohm-meter if you have one. If not and you are unable to verify that the fuse is working, buy a replacement fuse. Take the fuse with you to the supplier to ensure that you are buying one of the correct size and the correct rating. The rating is stamped into the silver end of the fuse, e.g 12.5A or 20A.
Carefully insert the new fuse into the fuse holder in the microwave and try to avoid touching anything else while doing so. Replace the panel and then try the microwave again. If the microwave still doesn't operate, then you have a more serious fault which is not user-repairable and you should seek professional advice. It is often cheaper to buy a new microwave than have an existing one repaired.
I hope this helps. Please post back if you need further assistance.
Regards,
BElectric
MY DAEWOO MICROWAVE KOR 1B4 H JUST STOPPED WORKING.
Maybe time for a new one. But just in case check the power outlet still has power and the circuit breaker is not tripped.
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
My maytag microwave blew the ciruit breaker a several times last night. I reset the circuit breaker each time. Then the last time, I reset the circuit breaker and the microwave did not get power back....
If there's no other appliance on that circuit, then please stop trying to use the microwave. You could be dealing with a dead short, and those sometimes leave people,,,DEAD!
I would be really cautious about trying to use it anymore without checking it first for a direct short.
You need to allow the circuit breaker more time to reset, flip to off and give it 2 minutes, then turn it back on. You should feel the distinctive click, as well as hear it if it's working properly.
Circuit breakers can go bad after repeated failures within a circuit.
The outlet could also be damaged now, but normally it's the circuit breaker getting too hot with repeated failures.
If there are a number of other items on the same circuit, then try the microwave in a plug that you know has no other items being used at the same time, preferably while wearing heavy duty leather insulating gloves to protect yourself from any possible shock. If the circuit breaker blows, you've got a possible electrical short within the microwave.
1helpful
Machine will not turn on
from online Microwave Repair Manual: Totally dead oven (no lights, no clock, no display, no fan, no heat...)First, check power to the outlet using a lamp or radio you know works. The fuse or circuit breaker at your service panel may have blown/tripped due to an overload or fault in the microwave oven or some other appliance. You may just have too many appliances plugged into this circuit - microwave ovens are high current appliances and should be on a dedicated circuit if possible. If you attempt to run a heating appliance like a toaster or fryer at the same time, you *will* blow the fuse or trip the circuit breaker. A refrigerator should never be plugged into the same circuit for this reason as well - you really don't want it to be without power because of your popcorn!
If you find the fuse blown or circuit breaker tripped, unplug everything from the circuit to which the microwave is connected (keep in mind that other outlets may be fed from the same circuit). Replace the fuse or reset the circuit breaker. If the same thing happens again, you have a problem with the outlet or other wiring on the same branch circuit. If plugging in the microwave causes the fuse to blow or circuit breaker to trip immediately, there is a short circuit in the power cord or elsewhere.
The microwave oven may be powered from a GFCI outlet or downstream of one and the GFCI may have tripped. (Removing a broken oven lamp has been known to happen.) The GFCI outlet may not be in an obvious location but first check the countertop outlets. The tripped GFCI could be in the garage or almost anywhere else! Pushing the RESET button may be all that's needed.
Next, try to set the clock. With some ovens the screen will be totally blank following a power outage - there may be nothing wrong with it. Furthermore, some ovens will not allow you perform any cooking related actions until the clock is set to a valid time.
Assuming these are not your problems, a fuse has probably blown although a dead controller is a possibility.
While you can do some repairs on your microwave, what you don't know can kill you... even on an unplugged microwave, so make sure you understand the dangers and how to reduce them before you try anything inside a microwave. If you want to do more yourself, go to the link at the top of this post.
Went to use my microwave and it wouldnt work. so i got another one and plugged it in to the same outlet and now that on wont work!
I wonder if your Circuit breaker or Fuse has blown on that outlet, please check that. Try the microwave in another Power point to prove.
1helpful
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
2answers
No Power at all
If it came installed in the house, it may have its own breaker switch. I'd check the breaker. Have any outlets in the kitchen gone out as well? This would support the breaker switch idea.
Hope this helps.
2helpful
I have a Ge jes1142wdc02
GE JES1142WD02 I would bet. If the circuit breaker and outlet powering the microwave are good, then the most common internal causes of a "dead" microwave are the fuse, a thermostat, or a control board defect. You can usually find local servicers in the Yellow Pages under Appliance Repair. I would pick the shop whose people sound most concerned, professional, courteous, helpful, and knowledgeable. Good luck.
Top Kitchen Ranges Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
john h
Are you a Kitchen Range Expert? Answer questions, earn points and help others
