20 Most Recent Amana Radarange Microwave Oven Questions & Answers
2answers
Microwave lights, clock, and everything
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
12/5/2017 3:32:51 AM • Amana Radarange... • Answered on Dec 05, 2017
My microwave over does not shut off
I'm sorry, I don't have an answer, but my radarange also began this odd behavior about a month ago... my son is a mechanic has almost forbade me to use it, stating he gets a headache everytime he opens it.... Once the range stops cooking, I open the microwave to get the food out, and the range immediately turns back on, lights on, and carousel turning! I have NO IDEA if the microwaves are engaged at this point???!!! But suppose I need to find out ASAP!
10/8/2017 9:34:07 PM • Amana Radarange... • Answered on Oct 08, 2017
Uninstalling an Amana Radar Range
4/7/2017 8:05:30 PM • Amana Radarange... • Answered on Apr 07, 2017
Amana radarange microwave oven no lights no sound display dead,
Then replace a thermal cutoff
3/4/2017 2:07:08 AM • Amana Radarange... • Answered on Mar 04, 2017
F-3 on amana radarrange
replace touch pad
8/13/2015 11:23:57 PM • Amana Radarange... • Answered on Aug 13, 2015
0answers
Amana ACM2160AS microwave is sparking
If it is sparking dont use it check for any metal or tin foil in it if the is none replace it would be cheaper than fixing
2/7/2014 8:39:36 PM • Amana Radarange... • Answered on Feb 07, 2014
Does not heat
You gave no model number or other detail. There are MANY possible causes. Fuse, safety switch, power supply, magnetron, control board. Check the fuse first. There is DANGER working on any device like this, and certain skills necessary. That's why they pay us the big bucks, NOT. If you insist on fixing it yourself, do a google search for your model oven, and download the manual. Please follow safety guidelines. Parts and repair help are available at: http://www.repairclinic.com/
1/16/2014 5:40:26 PM • Amana Radarange... • Answered on Jan 16, 2014
Over dose not heat
1/16/2014 5:38:50 PM • Amana Radarange... • Answered on Jan 16, 2014
Replacing a vintage Amana microwave door handle
Maybe this exploded view of the door might help you: http://www.easyapplianceparts.com/Schematics/Maytag/2665.gif
1/4/2014 2:47:49 AM • Amana Radarange... • Answered on Jan 04, 2014
Amana Radarange Microwave Oven Logo
167 questions posted
Top Amana Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Amana Microwave Ovens
Most Popular Question
f 3 amana radarrange
  • Microwave Ovens
