Hello Setup The Setup menu allows you to access the GUIDE Plus+ system setup information. To access the Setup option: 1. If the GUIDE Plus+ system isn't on your screen, press GUIDE on your remote control. 2. Press MENU to select the Menu Bar. 3. Use the right arrow to highlight the Setup menu selection. 4. Use the up and down arrows to select Change system settings, Review options, or View demo. • Change system settings Confirms the settings you completed in the GUIDE Plus+ system setup are correct. • Review options Displays the GUIDE Plus+ system auto display options. On Automatically displays the GUIDE Plus+ system when you press the ON•OFF button on the remote control. Off Disables the GUIDE Plus+ system from being displayed when you press the ON•OFF button on the remote control. Note: If you have not completed your GUIDE Plus+ system setup, these options will not be available. A Getting In & Out of the GUIDE Plus+ System To enter the GUIDE Plus+ system: • Press GUIDE on the remote. • Press and hold MENU for 2 seconds on the front panel. To exit the GUIDE Plus+ system: • Highlight a program and press OK to exit the GUIDE Plus+ system and tune to the channel. • Press GUIDE to exit the GUIDE Plus+ system and tune to the channel displayed in the video window. • Press CLEAR to exit the GUIDE Plus+ system and return to the original
Your RCA, system setup has changed I thinks.To change this you have to go to the Menu option surf for system settings, and change the system reception to "AUTO".
• View demo Runs the GUIDE Plus+ system demonstration
screen will prompt you to complete your setup.
channel
OK.
