20 Most Recent Sansui VRDVD5000 DVD Recorder/VCR Questions & Answers
look for an option in the DVD menu for dubbing this means to copy contents to hdd (usually cannot do it with copy protected discs but will be ok with a disc you made yourself)
Sansui VRDVD5000... | Answered on Jun 26, 2019
Put it on VHS mode put the DVD in still on VHS then on the remote push DUBBING.
Sansui VRDVD5000... | Answered on Mar 29, 2019
Make sure the DVD is not on the PAL system. Trying to watch a PAL dvd on a NTSC TV or DVD player will play it back in black and white only.
Sansui VRDVD5000... | Answered on Jan 13, 2018
If only you could tell us what brand of universal remeote you plan on using, maybe we could suggest some codes
Sansui VRDVD5000... | Answered on Mar 08, 2013
In the menu, you will find the control to click on finalizing the dvd-R. DVD +R does not need finalizing.
Sansui VRDVD5000... | Answered on Feb 11, 2012
  • Hi, I can help.
  • Have you cleaned the lens on your DVD player recently? If not it will get dirty and not be able to read any disks. Often times people just forget to do this.
  • If you go to Best Buy (or where ever) and get a lens cleaning disk and run it through your DVD player three or four times and let it get real good and clean. If the lens is extremely dirty you may have to fool with it for a bit to get the disk to be read to clean the lens.
  • These disks have little bristles on it that "sweep" the lens clean. Good thing is they are universal so you can clean DVD, CD, Computer Player. I recommend giving any disk players a run with the lens cleaner once a week weather you use it regularly or not.
  • It can also be the lens is worn out but I have seen many of DVD players end up in the trash from nothing more than a lens that needed a good cleaning. The lens cleaning disks cost roughly $10usd.
  • As for a direct replacement for your DVD Recorder/ VCR combo they are no longer made. The only place you will find these will be on e-bay and places like that. Being the great unit it is, if someone is getting rid of it, there is a reason for it. I would try cleaning the lens and if it works great and if not then this unit might be worth having someone put a new lens in for you.
  • If you have any comments please feel free to leave them here and I will respond.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Sansui VRDVD5000... | Answered on Sep 04, 2011
Hello
Just replace its strip that goes from laser assembly to main board first. Normally, this strip will get breaked internally and cannot be detected as they are carbon tracked, and always have to move along with the laser pickup assembly as the set works. If any one amoung this connections get a break, the fault you describes here will occur. Replace it first. If it is attached with the laser head assembly by mould; there is no way other than replace the whole unit. In some Sansui sets the fittings will be same as I reffered here. If it does not help you, laser pickup assmebly is faulty and should be replaced with same type and number. Insist on same number, as it is the critical part of your device. OK.
Sansui VRDVD5000... | Answered on Jun 08, 2011
that information is lost you have to start over again.sorry.
Sansui VRDVD5000... | Answered on Mar 04, 2011
Hi, I have a Sansui Model San1880, after I have manually program the TV channels, I don't get no sound at all only on the TV channels its got good pictures but no sound, would you please tell me what to do.
Thanks
Rod
Sansui VRDVD5000... | Answered on Oct 29, 2010
I believe the VRDVD4005 manual (which is the same as the VRDVD5000) is available on a Sears sponsered website called managemylife.com. I hope this helps you. Look under "Dubbing".
Sansui VRDVD5000... | Answered on Sep 02, 2010
hello,
the problem of this is from the power supply board of DVD player, try websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sansui VRDVD5000... | Answered on May 31, 2010
1) Power on player with no disc in tray
2) Press PAUSE
3) Key in 314159
5) For multi-region, select 0
6) Press PAUSE again
7) Power off player
8) Wait a minute turn it on.
Try that.
Sansui VRDVD5000... | Answered on May 27, 2010
all support DVD-RW or +RW these days
your problem most likely is that you downloaded some movie with an unrecognizable avi codec that runs only on PC. And you burned that on a dVD without checking with Virtuadub first the videoformat.
First test every movie with a DVD+RW that you can erase or it gets costly. If older type DVD-RW might not be supported
Sansui VRDVD5000... | Answered on May 26, 2010
On PC or stand alone DVD burner?
On PC tell burning application to finalize because you most probably are burning multi-session DVD's now and not all DVD players old type accept unfinalized discs.
On standalone: go with remote to menu item where to finalize that multisession DVD (these units always make default because of design multi-session discs)
I believe the VRDVD4005 manual (which is the same as the VRDVD5000) is available on a Sears sponsered website called managemylife.com. I hope this helps you. The customer service number should be on the back of the unit to order a remote.
Sansui VRDVD5000... | Answered on May 18, 2010
There should be a customer service phone number on that unit somewhere. If your willing to pay a few bucks you can call that number and order one. Hope this helps.
Found the manual here:
http://www.hammerwall.com/Download_Manual/9840/
enter the captcha code
then on the next page right click the MANUAL LINK, and choose SAVE TARGET AS to your desktop.
Setting the clock is on page 26.
Hope this helps.
Sansui VRDVD5000 DVD Recorder/VCR Logo
Popular Tags
86 questions posted
Top Sansui Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sansui Televison & Video
Most Popular Question
lost manual record from vcr
  • Televison & Video
