Washing Machines Logo
Posted on Nov 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I get the tool for Spanner Nut / Whirlpool top-loader washer.
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Dec 01, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
430233
Points
5400
You don't have to buy a special spanner wrench ($20) to remove the spanner nut. I've used a short 10" pipe wrench (about $9.00 also good for cracking walnuts) hooked over one of the tabs on the spanner nut, tap the handle with a hammer and it should loosen.
Also, don't directly hit the drive block with a hammer. Use a short piece of wood under the drive block and tap up on the wood.
How do I clean it?
If it is a top loader, you have to remove the agitator, then get a spanner nut wrench and remove the spanner nut . Pull the inner basket up and out and check the condition of the aluminum drive block for broken off notches in the center where the basket drive tube ears lock in. This is a common problem among top loaders made by Whirlpool for Sears.
tip
Whirlpool / Kenmore Washer - Drive Block
Whirlpool / Kenmore Top Load, Direct Drive Washers.
A number of the diagnostics and repair procedures for these washers require you to remove the agitator(s).
In order to get the agitators out, you need to remove the "Spanner Nut" and "Drive Block".
Many instructions call for a special spanner wrench to remove the nut.
However,
You don't need a special spanner wrench. (About $20 retail)
I've used a short 10" pipe wrench (About $9 also good for cracking walnuts) hooked around one of the tabs on the spanner nut and tapped the handle with a hammer to loosen it.
Also, don't directly hit the drive block with a hammer (it's soft metal). Put a short piece of wood under the drive block and tap it up with a hammer.
on Dec 01, 2009 • Washing Machines
HOW DO YU GET THE SPNNER NUT KENMORE 90 SERIES WASHER? I DO NOT HAVE A SPANNER WRENCH.
You'll really will need the spanner wrench for the spanner nut on the basket drive block. If you try to make a tool or use some other method, you risk injury and possibly damaging your washer basket.
The spanner wrench is made by Supco, part #TB123A. It has various other part numbers from the appliance manufacturers. It is compatible with Whirlpool, Maytag, GE, and Kenmore. Most Kenmores are made by Whirlpool.
If you want the wrench same day, call local appliance shops and ask if they sell the spanner for the Kenmore Series 90. I got mine from a local shop and paid $13.
You could also buy one on eBay or another reasonable online source.
http://www.ebay.com/sch/i.html?_trksid=p2050601.m570.l1313&_nkw=tb123a&_sacat=0&_from=R40
Or Google search: TB123A
Don't pay more than $20 including shipping.
You can always sell it on eBay once you are done with it. It won't lose much value being used since it doesn't really wear out.
You'll need a hammer too, preferably with a hard rubber head, or use a wooden mallet. If you use a steel hammer, be careful when you strike the spanner wrench to loosen the spanner nut. Wrap the steel hammer head in an old washcloth or rag. You don't want to accidentally strike the porcelain enamel lining of the basket - it will chip and that can lead to rust of the metal.
How do i remove the nut spanner from a new Whirlpool top loader washer (is it a right hand or left hand threading)
The spanner nut is standard thread to loosen/remove it turn it to the LEFT,you do need a spanner wrench like the one pictured here oldtech2332_37.jpgPart number for that spanner wrench is TB123A It can be purchased at your local appliance parts store or online at;
searspartsdirect.com
repairclinic.com
apdepot.com
midwestapplianceparts.com
apwagner.com
How, can I clean the washer. I washed many time my husband dirty coverols and now its effects my washings.
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
KENMORE top load, direct drive, neutral drain washers are made by Whirlpool.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The best way to completely clean the washer is to pull the agitators and drum in order to get to the tub.
Following is the Whirlpool / Kenmore Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Following is a description of how to remove the cabinet, pump, motor, transmission and basket drive tube on Whirlpool / Kenmore / Roper direct drive washers.
As an aside, you don't need a special spanner wrench to remove the spanner nut. I've found that a short (10") pipe wrench hooked over one of the spanner nut tabs and tapped with a hammer will usually loosen the nut. Also, rather than hitting the Drive block directly with a hammer, put a short piece of wood under it first to protect it.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Kenmore 90 series , Brake doesn't engage basket after spin
This assumes that you have a basic Sears / Kenmore / Whirlpool top load, direct drive washer.
See the Sears diagram or the following Whirlpool Service manual
The washer uses a brake system to stop the basket at the end of the spin cycle.
Just like a brake on a car, it's designed to slip a bit so that the basket / car doesn't come to an abrupt halt.
Over time, the brake shoes can jam against the brake drum and bring the basket to a halt too quickly with a lot of noise.
It sounds as if your brake shoes are worn / damaged.
Following are the Whirlpool Service manual for this type of washer and the Whirlpool parts list for their commercial washers although the consumer models are basically the same.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
I'd pull the drive tube and check the springs, shoes and plastic cam that hooks onto the clutch spring.
Although Sears sells a complete drive tube assembly, you can probably get only the parts you need (shoes) from Whirlpool.
Kenmore 70series top loader: end of spin cycle the
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
A couple of possibilities.
1. The Brake Cam Driver in the brake assembly (a plastic piece could be broken.
2. The break springs may also be broken.
Following is the Whirlpool / Kenmore installation and maintenance guide for direct drive washers. It has a section on how to access and replace the brake and drive tube.
You'll have to remove the agitators and the drive block. There is a spanner wrench to remove the drive block nut but I've found that a short 10: pipe wrench hooked over one of the nubs on the nut and sharply taped with a hammer will loosen it.
Please see GURU JSROCK516 Description of how to remove cabinet and access the transmission. http://www.fixya.com/support/r699497-replacing_gearcase
1helpful
Spanner nut removel
Hi, The proper tool is P# TB123A.
You can also use a coal chissle and a hammer. Be careful that part of the spanner nut doesn't break off and hit you with the chissel. It takes a preety solid hit to losen the nut.
Hope this helps. If it does, please rate my comments and how I did in helping you. You can order the wrench as well as any other parts on my web site
http://www.whirlpoolpartssurplus.com/cart/
Top Washing Machines Experts
john h
