Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it.Here is a video for the element replacement.Here is a video for the thermostat replacement.
Try this video if calls for front panel access. Please let me know if this works for you.
Sorry.... here is that link to the video! I forgot to attach it.
I'll be around if you need me. :)
Here is the one for the Element
http://www.youtube.com/user/RepairClinic...
I watched the videos that you sent to me. i just picked up the heater element part and also came with dryer thermal cut offo fuse kit. I wanted the videos that you sent with your response, however the printed instructions that came with the part states that I am to remove the dryer front panel not the back panel. How do I remove the front panel?
I will be trying to replace the heater element and thermal cut off fuse tonight when I am done with work. I may still be in touch during the process of repair.
I am home and want to rewatch the videos and when I click on them it tells me that an error has occired and to try again later. Can you please resend them?
