HP OfficeJet D135 All-In-One InkJet Printer Logo
Posted on Jun 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Won't print in color
My hp officejet d135 All-In-One printer won't print out in color. The black works just fine but even when I put a new color cartridge in, it won't print in color. Also, the alignment "test" paper that prints out is only in black and white also. It shows no color. HELP!
Tim Babcock
Level 3:
  • HP Master 2,794 Answers
  • Posted on Jun 22, 2008
Tim Babcock
HP Master
Level 3:
Answers
2794
Questions
13
Helped
1128433
Points
7249
Is the color cartridge new and do you know how to check the gauge in your control panel for the ink levels?
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
1helpful
Can i substitute my color cartridge with a black cartridge. I am using a hp officejet D135. I may need to get a new printer but I can't test it because I am out of color ink and I don't want to buy one to...
No !!! First of all they are not the same size so the black cartridge most probably won't fit on the color slot, and if for any reason you need to print more with it, the black ink would have left its "mark" inside the color ink the injectors.
HP D135 PRINT error
I am sorry the print head goes out on the B And W on these things quite frequently. however you can go to www.hp.com amd go threw thier secdualed way of testing the print head but am sure you will find it defective. I had one and it was a problem. B e aware they have a new head that replaces the old head that lasts much longer.
Hp d135 copy function makes copy in green instead of black
ur tri color cartridge may have run out. change it and try again. if it doesn't work try calibrating ur scanner.
Hp officejet d135
You can't, all carts must have ink in them
9helpful
2answers
Officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
HP D135 Wont Print IN COLOR!
Dacy, Go into the printer properties and check and see if it is set to print in grayscale.
Please let me know!!!
thanks
Troubleshooting
your printer heads are clogged.
k24674
Grand Canyon Tech
Grand Canyon Tech
